NukeULater
- Sep 12, 2006
Some of you might of seen my first mod ever. I've been using it a lot recently and it was starting to look boring. So I'm going to rebuild it from scratch.
Heres what I started with, thats already after modding. It was all beige...
Then it went to this.
And so I start again! First thing on the list is to clean up the cables. I'n going to cut by those red marks.
You will see where this is going... Yes I reversed the hard drives all the cables now stick out the front of the case.
New power switch, is on it's way to. One day this case will be used for a server. So I went with a locking switch, thats mounted on the back of the case.
The place to mount it, it was once where a speaker was mounted. It's also going to be the place for the CCL switches.
I used a .75 inch spade bit to cut the hole.
The new wire management... The hard drives are reversed it the photos. Ignore the CCL wires they will be hidden later.
And I also frosted the side window...
More to come! I'd like to here what you thing about it.
