Project: LianLi A10 Black'n'Blue
Hello everyone!
I want to present you my LianLi A10 casemod. I searched a big case for my new watercooling and I found the A10. I hope I can realise and intergrate all the things I planed.
What is planned?
- case black powdercoated
- cuts for the watercooling
- 2 cuts for triple and dual radiator
- build a bracket for the Laing
- window
- topwindow
- hdd watercooling
- LEDs?, fans?
- blue highlights
- sleeving all cables
- clean design
Reasons for the project:
A new watercooling. My old watercoolings were.. lets say suboptimal.
Lets start:
original state:
the original state , you can see here, in this user review:
http://www.hardwareluxx.de/community/f141/lian-li-pc-a10-review-286793.html
Start at 05-08-2010:
two weeks ago, the case came back from powdercoating. As you can see the coating is not perfect BUT it was for free... i think they had no motivation to do it better... :p i try to hide the parts with low quality as good as i can.
Not a good start in my opinion...
Other parts look much better:
On this part the coating is not that bad:
This is the place for the laing:
The laing will be mounted with two elastic bands.
At the ground level, there will be:
PSU
Triple
Dual
Single
I'm not able to realise the project on my own, so i'm sponsored by:
Aquatuning.de
http://www.aquatuning.de/
Special thanks to Mr. Schultze!
The Plan for the next week are the cuts for the watercooling parts, maybe the hdd cooler.
I hope the project will not take too long ;)
Please forgive me if my english is not perfect, i'll give my best!
Have fun with the log.
Lighthammer2
THX :)
Hope you can understand most things I'm writing :D
Here is the next update:
A new Mainboard and new Ram arrived:
It's a MSI 790FX-GD70 and Micron Ram (1600 7-7-7)
I came from an old Biostar AM2+ Board with crappy 2GB MDT "AMD Only"
I started reassembling some parts of the case. I made some pics:
You see the Mobo and most of the case parts. The Midplate isn't fixed yet.
Here you can see two radiators with the first part of the tube ;) Everything fits perfectly.
The single radiator changed his position:
Find a new place in the mainboardtray. Theres also the first AGB.
Another pic of the mobo:
I think its quite nice ;)
Black rivets and screws are orderd from MDPC-X.
Also i ordered a Scythe Himuro for my HDD.
The next plan is:
- Cuts for the triple radiator
- inlay window. which color should i choose?
lightblue? clear plexi? grey?
- Topwindow with aquatuning engraving
- cut for agb in the top
sorry for the bad cam!
The paint isn't perfect.. but it's okay. Most of the faults can not be seen if the case is finished.
Here a small update:
I found the mat in the aquarium section of an supermarket. I tried to isolate the HDD. Therefore, I cut out 4 pieces.
Sticked the 4 pieces together and glued it on the Scythe Himuro.
overall picture:
Fits well, don't know if the isolation works. Computer doesn't work yet. ;)
