Hey guys. Long time viewer, first time poster to these forums. Just wanted to show off my best (so far) custom mod. No sheet metal, or custom acrylic. Just a case built entirely of legos. I always loved legos, so I figured why not? I'll build a computer out of em. My goal was to make it look clean, and to use no glue, or screws. I had to fudge a lil bit with the screws. 4 hold the motherboard to 2x2 lego blocks, and 2 hold the front side USB bracket in place, since without them, the force to put a USB device in was snapping off the frame of legos I made for it. Anyway, stop my yammering! pics!
I know what you're thinking: why the hell is the DVD rom gray? Well, I'm thinking the same thing. I just haven't had a chance to paint the bezel yet. My old drive died on me, which was black, and I needed a replacement. This one was sitting unused, so I swapped them. Just haven't gotten around to dying it.
the inside of her. She's running an athlon XP 2400+, radeon 9600SE, ATI tv tuner card. 30 gig hard drive, 230 wat SFF PSU all strapped to a Velocity Micro V6DP motherboard. Some of these specs are kinda low end, but I had a limited budget at the time, and used as many parts as I already had. My apologies for the size of the images. I submitted this to a case mod competition, and wanted to make sure the images looked good. If you wanna see other pics, I have some. Let me know what you guys think.
![front_top_left.jpg](http://netfiles.uiuc.edu/slturne1/www/Lego_Pics/front_top_left.jpg)
![inside.jpg](http://netfiles.uiuc.edu/slturne1/www/Lego_Pics/inside.jpg)
