The Large Wooden Tower case build is done:
(That particular case was sized to hold an EATX MB and two 120x4 radiators in the top chamber. However, the basic design of the case could be easily adjusted to accommodate 140mm radiators, EVGA's 4-Way SLI MB, etc.)
This next phase of the project involves adding the wc-ing goodness.
But before I can do that the case requires some further customizations involving stealthing the 5.25-inch drive cage and power supply area, as in:
The power supply "cover" is really just a simple two-sided divider.
