It's so weird to see 120mm fans in this case, they look like 200mm ones. I will probably wish I had 12 year old's fingers just to install everything as my manly sausage fingers will most likely get in the way even more than any other SFF build.
If you like this kind of stuff, I recommend you try to get a hold of a PowerMac G5 or Mac Pro case for some modding project. I did one and I was amazed how a 10 year old case like the PowerMac G5 has such an incredible amount of engineering genius put into it. The newest Mac Pro (the polished black aluminium tube SFF piece of art) is even more amazing:
http://www.youtube.com/watch?v=IbWOQWw1wkM
Even if you don't like Apple, it's hard to argue their computers aren't inspiringly well engineered.
Can you please take some pics of the drive cages.
Thanks for the work log!
Even though this build is coming off rougher than an old band-aid on a hairy arm, I am having a good time with it. The case is such a dream to work with; all the parts fit together sensibly and logically, the fit and finish are top notch, and it just seems like a high-quality piece.
Its my research skills that aren't up to par. I keep getting parts that don't or won't go together, and if I'd gone more slowly and done my research ahead of time I would've figured that out without dropping a pile of cash on a CPU cooler on whose manufacturer's website it clearly states that said CPU cooler will not work with the motherboard I have chosen.
To pick a random example, which may or may not be true.
More to come!
Awesome seeing your build come together! Absolutely loving the pictures, appreciate the effort that goes into doing so.
So the fan filter limitation is the lack of space between the fan mount and the side panel.
The demci would still work because it doesn't add to the thickness under the screws? Does this therefore mean that its raised screws that are the concern? (modding required, but if we found a lower profile way to mount the included fan filters, that should work fine? Thinking countersunk screw heads with appropriately prepared countersinking.
A fast update; I am trying to keep my momentum up.
Progress:
More to come!
In my experience, the supplied Lian Li filters will almost fit under the side panels, the difference being about 1.75mm. However, the supplied fasteners have domed heads that stick up an additional 2mm on top of that, which REALLY doesn't fit.
I tried some small-head, countersink-type fan screws (I am certain that everyone has some of the same screws; like AC power cables, they multiply in dark storage boxes and drawers), which worked pretty well but the filters still sit proud of the frame.
So, as Necere said, the supplied LL filters don't quite fit.
The vents on that side extend to about 60-70% of the width of the intake fan on the ST45SF-G, plus there's 2-3mm between the PSU and the side panel.Isn't the PSU fan / air flow blocked when the gold version is mounted that way?
It's all aluminum. I actually physically checked on this exact case whether the Demciflex filters w/non-ferrous backing would fit between the bracket and side panel, and they do.So the clearance of the side panel is not sufficient for the thickness of the filters alone, let alone the screws. Is the fan panel steel or alum? Demci filters are magnetic, but onto aluminium we will be needing the magnet strips too. By the sounds of it (and by your photos), there is only 1-2mm of thickness available...
Nice worklog! I just discovered it from google spreadsheet.
I´m very curious about GPU and your solution with 2 big fans.
I'm going to try it with just one 12cm fan at first; hopefully, that will provide sufficient airflow across the heat exchanger to keep the GPU temp low.
I mounted the single fan in the center fan location (which I suspect might not actually be intended for a fan, but for support hardware for bottom-mounted radiators... Nevertheless, the mounting holes are placed such that a 12cm fan fits perfectly, right in the center of the bottom panel) so that the fan's airflow is not-quite directly onto the heat-producing GPU.
The result should be a nice convection current that pushes warmed air out the back of the case and up and out the top and draws in more cool air from the bottom.
How about GPU power connector? Is there enough space for the wire to make the curve to PSU?
By the way, I´ve heard Silverstone SFX is a bit noise. They suppose make it better on v2.0. Do you have idea how can I tell if the version is 1.1 or 2.0 when buying online?
Any update about your GPU with big fan on the floor?
What sort of part did you use for those WC hole caps? I would like to hunt some down for my build.
I am sourcing a connector to replace the stock PWN plug on my big fan with the one on the card, so that the card can control the fan speed.
Mostly, I need to make some time to get to the electronics supply shop on the other side of town.
Those are custom-ordered, specially-cast one-off caps made from myrrh by the finest Chirobistan craftspeople.
I kid, I kid... they are 1 inch / 2.5cm nylon caps from the hardware store.
My local (Westmoreland TrueValue) had them in black or white nylon and a couple other materials.
Any reasonably well-stocked DIY shop or home center should have a selection of plugs/caps for a range of sizes, if you don't have a hardware store handy.
If you can't find what you are looking for, just ask the friendly staff; they live for helping you find this kind of thing in their store.
Yes, sorry... Thanksgiving has absorbed a lot of my time since last week, so I have not made much progress.
My connectors are in, and I am getting a LOT better at crimping those tiny buggers.
I haven't taken any pictures, just imagine yourself swearing at a crimper, some pins and a spaghetti-tangle of wiring, instead.
