daedal said:Gotta figure out how I'll pass the LCD's wiring through so that I can still open the doors. Any ideas? I was thinking of making some holes in one of the 5.25in bays and pass the wiring through some wrap in there.
Aww man, I was so excited working on this.. until it came to the price.1337m0dd3r said:Looking good man and on that machinist there is this site that will ship anywhere ... I gotta find the link for it again..
-edit- I'm not sure if this is the same one or not... I can't find where they ship too.. but whatever I'll keep looking http://www.emachineshop.com/
damn man.. that sucks : / I could that machined at the local shop for a whole hell of alot cheaper then that.. mmm I try'ddaedal said:Aww man, I was so excited working on this.. until it came to the price.
For a simple 12.5" ring with drilled bolt holes, we're talking about 30 days wait and 300$ US.. pass.
Thanks though. I appreciate the gesture.1337m0dd3r said:damn man.. that sucks : / I could that machined at the local shop for a whole hell of alot cheaper then that.. mmm I try'd
daedal said:--------- <- Aluminum (thin sheet) <---- DREMEL
======= <- Noise isolation material (plastic, sort of) <---DREMEL
Pictures to come tonight.
Well before I cut the hole for the LCD, I need to check that the door will still close once it's installed on there. Hopefully I'll be able to squeese in some time to do that tomorrow after work. The LCD spent the day in the car at -30c, I hope it's alright..sev said:Why dont u try some skillful dremel work, cut out your main hole for the LCD then carfully cut off the two layers you dont need after that.
daedal said:Well before I cut the hole for the LCD, I need to check that the door will still close once it's installed on there. Hopefully I'll be able to squeese in some time to do that tomorrow after work. The LCD spent the day in the car at -30c, I hope it's alright..
As far as the side panel is concerned, a member on another forum mentioned maybe tried a router saw and see if I can thin out the edge to allow the molding to fit. Any thoughts on this? By the way, I seem to have missplaced my camera. I'll post more pictures when I find it.
I tried to use the smaller ones (erinforced) but they were too smal in diamater to go through the entire panel so I used these larger ones which tend to break off. I'll see about sticking to the reiforced disks next time though.thore said:yeah... dremel disks are fun like that... now you know why we sing the praises of reinforced dremel disks, there more enpensive, but they dont break, you will go thoguht 5 disks trying to make the same cut where one reinforced will only use half a disk...
wait untill you get one imbeded in your knuckel...
thore
daedal said:I tried to use the smaller ones (erinforced) but they were too smal in diamater to go through the entire panel so I used these larger ones which tend to break off. I'll see about sticking to the reiforced disks next time though.
