Project: Kustom Kooled v2
Dillusion
Well its about time I changed things around and I've changed taste a bit in the recent weeks. My last mod 'v1' I guess (of this Lian Li PC-7B Plus) was a red-color based mod with red UV stuff in it. Turns out I didnt like it and gutted it. I took allot of things out and I'm going for a much simpler approach. Its still going to be a UV reactive watercooler box, but with a nice mix of high-end air cooling and watercooling. This may not be a huge overhaul of a case but It's my little worklod none the less :p
Heres a teaser image of whats to come in the following week as I recieve parts and ideas:
The GPU and NB will be cooled by STASIS Thermal cooling products. Matt @ STASIS Thermal is kind enough to let me BETA test one of his all-copper NF4 series northbridge coolers as well as send me a custom RED lucite version of the STASIS Thermal NV6800C5RS GPU cooler. With the Uv reactive lucite for the GPU and some neat UV-Green Primoflex tubing I picked up should make for an interesting mix. I'm also bringin polarFLO into the mix with thei acrylic TT series CPU watercooling block.
Specs will be as follows:
MSI Neo4-F nForce 4 Motherboard
AMD64 3200+ (CBBFD0441RPMW :cool:)
Corsair TWINX1024MB-3200C2
ASUS PCI-Express x16 6800 256MB 256-bit
And the usual suspects to top it off...
I will post an update as soon as the rest of these parts reach me by the end of this week. Ideas and questions welcome.
If anyones looking to see how these new cooling procuts perform be sure to check back as I should have results posted aswell.
Prepping the parts for mounting and leak testing:
Waiting on care package from STASIS Thermal, RAM, and seagate RMA.
Small Update:
I ditched the Neo4-F and got a board with 3.55vdimm so i can overclock these Mushkin UTT chips i just got in today. Should have the board by tommorow and the STASIS package by friday.
Well I ended up ordering an Abit AN8-Ultra which had the heatpipe cooler on it so another air cooler was pointless. So I was offered a BETA 3/8" Water cooler NF4 block but then I ditched WCing. Rest assured I will still give you guys the info on the NB blocks when I have the go ahead from Matt @ STASIS :)
Im still waiting for parts right now...
