So after doing my Iori Yagami mod on a crappy case with a crappy computer
http://hardforum.com/showthread.php?t=1287508&highlight=iori+yagami
Pentium D 805 2.66 GHz (Thing ran so hot 60C in BIOS and most monitor programs wouldn't recognize the Processor)
8600GT
2GB ram
yadda yadda yadda
I start with a new case and new computer
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119149&Tpk=coolermaster+340
Q6600
8800GT
2GB ram
yadda yadda yadda
Main reason to get this case too because it fits Tuniq Tower!!!
I wanted a microATX case because when I travel to LANs everything is much easier to haul. Basically I started with the foundation of cutting holes out of where I needed them.
http://www.bestgameffvii.mysteria.cz/img/FFVIIAC-Jenova.jpg
There is a picture of Jenova for reference (FF7 series). The colour I want to emit from the case is the tealish colour of Makou energy, and for it to be soft, and blend from Green/Teal/Blue/White so the colour is inconsistent all the way around.
I also plan to put a window on the side of the case and put a decal or applique on the window of the above picture. And behind where the eye is red put a Red LED there that is attached to the HDD activity.
Which brings me to my next question:
Does anyone know what voltage the motherboard gives to the HDD LED?
And I shouldn't have problems splicing the Regular HDD LED and the new one I add on the window in parallel so they will both be attached on the motherboard correct?
8600GT
2GB ram
yadda yadda yadda
Q6600
8800GT
2GB ram
yadda yadda yadda
