Thanks to everyone who gave great advice.
Case shot with my new USB Xbox controller setup for Toca 3:
I snaked the radiator fan's speed control through the 3.5" bay slot and put it in the rail guide. I'll secure it when I lengthen the other speedcontrollers and put them in.
I ended up using the aquajet to keep bubbles from re-entering the system, I'm a little disapointed in the aquatube in that respect. If it weren't for its killer looks I would have just gone with a T-line. The reservoir is mounted on the drive rails so it slides out for easy refilling and draining. The fill port is on the top of the res so I don't have to unhook anything when I fill.
I could have done better with cable management considering the case I'm happy with the the minimal effort it took to hide as much as I did. Big thanks to Erasmus354 for rad placement idea. It really fits in there like a glove. Drilling and cutting took me no more than 10 minutes and the fan bolts right up to the stock location. Easiest mod ever
Here's where I notched the bottom drive bay to give my tubes a little extra room. The cut is rounted off but I'll cover it in rubber trim later just to make sure.
All in all I'm very happy with the results. The P180 was practically made for this project as you can see with the PA160 placement. My overall goal was complete silence from an internally mounted WC setup and I feel I've hit the mark. With the front door shut I can't hear the computer at all.....in fact, I've discovered that my monitor has a really annoying buzz that makes me want to jump out the window. Idle temps before were about 60* C on the CPU and 6800. Load temps spiked up to 70* and 79* respectively. WC temps remain constant at 38*/40* and 43*/44* under load. Case temps are 41*. All fans are stock Antec fans set on low. All of that is measured with ASUS's motherboard utility so take it with a grain of salt. I'm sure I didn't apply the Arctic Silver properly and another rad would probably help but such is life. I haven't tried overclocking yet because I'm having some memory issues but overclocking isn't a huge concern...silence (and the constant urge to mess with stuff) was.
Equiptment added in this build to quiet the old computer (which could be heard in the next room):
Swiftech Apogee (no shavings...yaaay!
Swiftech MCW-60b
OCZ ramsinks
Eheim 1080 (a lot bigger than it looks in the pics btw)
Noise Isolator relay board
Antec P180
Aquacomputer Aquatube with Jet, Led, and drive bay
Seasonic S12 (friggin awesome PSU imo)
Samsung Spinpoint 250 GB SATA 3.0gb/s (the switch to this from my old ATA drives eliminated the majority of my case noise. I higly recommend the Spinpoints to anyone looking to quiet their comptuers)
Pioneer DVR-111D
Remaining stuff:
160GB WD SATA HD.
3.0 ghz P4
ASUS P4800-E (crap mobo IMO)
2 gig Patriot ram
PNY 6800 (unlocked and OC'd)
M-audio revolution 5.1
Thanks to everyone on the WC forum for their help. I'd also like to give www.performance-pcs.com a plug....their support was out of this world (emailed me back in just over an hour) and their shipping time to Phoenix beat Newegg and Zipzoomfly by a day.
Swiftech MCW-60b
OCZ ramsinks
Antec P180
Pioneer DVR-111D
Remaining stuff:
160GB WD SATA HD.
3.0 ghz P4
2 gig Patriot ram
