Project Intel Ice
Discussion in 'Worklogs' started by jjsky5000, Jun 11, 2010.
  1. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Well after a long break I am back at doing some modding projects, I have 4 total that I wanted to have completed by the end of the year.
    The first Mod is called Intel Ice, Featuring a IntelĀ® Desktop Board D945GSEJT Atom CPU mini itx Board Sponsored by Intel, Looking to make it my Home Media Server. I t will set in a a Custom fake arclyic ice case. Let Begin
    Parts List
    Plexi Glass
    Plastic Resin
    Vandal Switch
    DC power adapter ( on order)
    IntelĀ® Desktop Board D945GSEJT Mother Board Sponsored by Intel!!!!
    PCi min express wireless Card ( on order)
    Wireless Logitech Keyboard and mouse
    Western Digital hard drive
    Win 7
    2 80 mm Blue led fans
    mixing bowl /wood spoon
    alumin foil
    2 boxs one slightly bigger than the other!!!
    Not sure what happen to the pictures ????
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The mold Not much Card Board and aluminum foil
    Lets Begin
    [​IMG]
    64 fl oz of Plastic resin 1/2 oz of catalyst hardner
    Mixed it it for 60 sec
    [​IMG]
    Poured the top of the case in the moldto about 1/2 inch deep. Then waited 30 min till it start to gel then I put a second box on top to make inside walls. pour the remaining resin in to make the walls.
    [​IMG]
    I had to apply a little weight on top of the inside box to keep from floating up.
    This will set overnite to cure and make sure you are in a well ventilated area.
  2. Rossi~
    Rossi~ 2[H]4U
    3,488
    Dec 8, 2008
    Very interesting indeed :) I will be keeping an eye on this build
  3. Mr_Armageddon
    Mr_Armageddon Limp Gawd
    252
    Jun 3, 2009
    Looking forward to seeing the end result. Good luck.
  4. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Time to un wrap
    I did spray a resin release agent before i poured the mold so it would stick too bad.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    To square it up I did a little cutting with a dremal & hack saw!!!
    [​IMG]
    Ok took a few shots to see how it looks on different surfaces
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    a little more work on the cover and then i will start on the base
  5. Crispy002
    Crispy002 [H]ard|Gawd
    1,340
    Sep 3, 2008
    That's one legit ice block. Well done.
    Is there foil on the inside part or is that just the reflection?
  6. lorelei
    lorelei [H]Lite
    78
    Sep 17, 2008
    Looks awesome all ready...Can't wait to see more pics :)
    [​IMG]
  7. Timonthy
    Timonthy n00b
    63
    May 29, 2010
    Wow, what a cool idea. (slap for bad pun :))
    Look great form what I see. Giant ice-cube for sure.
    But just asking, how are you going to fit the I/O shield/HD bay without compromising the looks?
    Hope everything goes well!
  8. jackofalltrades
    jackofalltrades 2[H]4U
    3,641
    Feb 7, 2006
  9. AlucardCasull
    AlucardCasull n00b
    14
    Feb 8, 2004
    Very cool, ill be watching
  10. Negative Decibel
    Negative Decibel 2[H]4U
    3,612
    Dec 13, 2005
    really cool. can't wait to see more.
  11. HaX
    HaX [H]ard|Gawd
    1,914
    Dec 17, 2005
    i look at it and i get confused.. in a good sort of way :D
  12. Hallis
    Hallis [H]ardness Supreme
    4,565
    Oct 26, 2001
    Wow!. That's an awesome idea and looking great so far.
    @Timonthy - I think he's going for a look like it's all frozen in ice like a caveman. If it were me i'd not put the I/O panel on the outside, rather leave some space inside and then just route the cables out through little notches in the ice. Would have to have some space between the edge of the case and the backplane of course to fit the connectors. But I don't see that being a gigantic issue just yet.
    I can't wait to see how the wiring is done. Especially the power supply.
    shane
  13. oahawhool
    oahawhool n00b
    52
    Jun 10, 2010
    Excellent execution on a really refreshing idea for a mod!
  14. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    @Timonthy The back plate & base will be made of a regular Arcylic , with the i/o cut outs on the back and a fan cutout on the bottom.
    @Hallis No internal PS. The Intel Atom low Volatge you can use a a 12 v dc to dc adpater. It really cool, only wires are hard drive power and 1 sata cables, Win7 will be preloaded, and everything shared on wireless,
  15. zer0gravity
    zer0gravity Gawd
    978
    Dec 8, 2008
    Can't wait to see the case! Also, good to see HTPC mods!
  16. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Update #3 Dont have a lot of pictures tonight , but it took me two days 2 complete this update.
    The case need a little something. how about some "Illumination"
    [​IMG]
    it took a couple of hours over the 2 days to ecth!!!!
    [​IMG]
    Doesnt look too bad
    [​IMG]
    Lights on
    [​IMG]
    [​IMG]
    and with the lights off
    [​IMG]
    going to add a few more led to even it out!!!
    looked much better in person!!!
  17. Herl
    Herl [H]Lite
    65
    Aug 28, 2008
    Very cool. I'm surprised you hand etched the logo, seems like it would be incredibly difficult and time consuming.
  18. LibertySyclone
    LibertySyclone [H]ard|Gawd
    1,375
    Apr 9, 2007
    I am with him /\ I would have used a sandblaster and a reverse cut vinyl sticker.
    Either way its kickass cant wait to see the end result!
  19. shoto1699
    shoto1699 Limp Gawd
    444
    Jun 16, 2010
    nice! looks badass man. im excited to see the result! also good luck!
  20. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    Very cool! The illumination looks excellent. Very unique build :)
  21. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Update 4# Just another little update.
    Worked on the base as well as the fan cutout
    1st I made some cuts into the case for the base to fit in.
    [​IMG]
    [​IMG]
    Cut a square piece of acrylic to fit
    [​IMG]
    Made some reminders
    [​IMG]
    A little tapping action
    [​IMG]
    [​IMG]
    attached the base
    [​IMG]
    A nice solid fit
    [​IMG]
    Looks like a good place for a fan
    [​IMG]
    Did pretty well getting it start by hand, did finishing using the drill at very very low speed
    [​IMG]
    and the end result
    [​IMG]
  22. Hallis
    4,565
    Oct 26, 2001
    Looking great so far. I hate hate hate cutting lexan and acrylic. I always tend to go to fast and melt it right back together lol.
  23. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Update 5#
    Final got some free time to work on the MB Brackets & base.
    Cut out for the rear panel!!!!
    Before
    [​IMG]
    Half way
    [​IMG]
    Done
    [​IMG]
    Rear panel
    [​IMG]
    Fits perfect
    [​IMG]
    I/0 Cut out hole
    [​IMG]
    Another test fit
    [​IMG]
    Going to use a Peg and glue method to attached the base together
    [​IMG]
    [​IMG]
    [​IMG]
    Worked out well !!!!
    Started working on the MB Support using my new tool.
    This is the most squared piece of plexi i have every cut lol
    [​IMG]
    Thanks for the compliments and stopping by !!!!
  24. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Big Update!!!!! Alot of it was done over the past 2 weekends in my free time.
    Holes for the hard Drives
    [​IMG]
    another test fit
    [​IMG]
    ooohhh what's Inside
    [​IMG]
    another pic
    [​IMG]
    Find a Clean spot !!!
    [​IMG]
    A very good plexi cleaner
    [​IMG]
    ahhh Nice and clean
    [​IMG]
    Getting ready to mount the hard Drive
    [​IMG]
    and the fan
    [​IMG]
    Underside view
    [​IMG]
    I forgot to take pics of the motherbaord being mounted but here is from teh test Fit.
    [​IMG]
    [​IMG]
    a little bit uneven , might have had a little to drink lol
    [​IMG]
    Eye candy
    [​IMG]
    Now for some wiring
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Hard Drives & fan wired up
    [​IMG][​IMG]
    A little test boot before i get to far in
    [​IMG]
  25. Crispy002
    1,340
    Sep 3, 2008
    So far so good!
    I might suggest a thin plastic sheet or some sort of barrier to prevent any possibility of the mobo shorting on the hard drive cover though.
  26. zydas
    zydas n00b
    10
    Feb 26, 2010
    Looks good. Was wondering where you ordered your power adaptor?
  27. vsboxerboy
    vsboxerboy 2[H]4U
    3,674
    Oct 17, 2005
    Assuming it's what you had laying around, but why not go with a 2.5" HDD or SSD? Otherwise it looks fantastic
  28. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    I got teh DC adapter on Ebay it was liek a 15v 3 watts for $15 dollars made for net books and teh atom MB
    I do have a sdd around. this project was for fun i have 3 other projects coming. didnt have a use for that partivular hd
  29. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Update 8 & 9
    added the vandal switch
    [​IMG]
    [​IMG]
    Cut & glued The case feet
    [​IMG]
    [​IMG]
    [​IMG]
    added the ecthing to the case
    [​IMG]
    [​IMG]
  30. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Final Pics Before operating system install
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  31. vsboxerboy
    vsboxerboy 2[H]4U
    3,674
    Oct 17, 2005
    Siiick, can't wait to see what it looks like with the OS isntalled! :p
    Beautiful final product though, amazing vision to have the foresight to see how this would turn out. Did anything not go as well as planned, because it looks damn good to me!
  32. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    the toughest part was The liquid resin. that was a big $60 dollar uknown.
  33. NICKSTAR
    NICKSTAR 2[H]4U
    3,787
    Jan 18, 2009
    Very nice man! Good job. Cant wait to see the next project
  34. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
  35. mrbrad
    mrbrad n00b
    24
    May 26, 2010
    Fantastic. Looks great in the dark. I generally don't go for "theme" mods, but this one is very nice.
  36. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Currenty working on adding 4 leds in the corners!!!
  37. jjsky5000
    jjsky5000 Limp Gawd
    146
    Oct 14, 2009
    Some outdoors pics
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  38. Jesse B
    Jesse B [H]ard|Gawd
    1,631
    May 30, 2010
    That looks awesome! Fantastic job :D
  39. picool
    picool Limp Gawd
    203
    Dec 10, 2009
    awesome work!!! It looks so cool!!!
