rogue_jedi said:that finish looks pretty sweet, but i don't really understand what is going on with the flames there.
in the last pic, its just a pic of the paint that started to kinda peel... so i have to redo the whole paint job again
ClayDo said:flames need more red in them..![]()
3N1GM4 said:I have it here on the desk with 4 50ft cords running downstairs to my garage....![]()
gigglebyte said:one question I don't remember seeing in the thread is don't you think there is going to be restricted airflow for the rad? from what it looks like you will have 1/3 to 1/2 blocked with the four port design...it looks killer but do you know how it will perform?
CrimandEvil said:It does? I had a hard time trying to find out how to make an assignable shortcut key that does eject. Finally someone over at the Bit-tech forum wrote a little command line app. So now I have it assigned to a button on my remote.![]()
Oh that, that was too much a hassle IMO. Damn, I'll have to go through and find the link for you guys.3N1GM4 said:if you right click on the cd-rom icon there is "Eject" option...
3N1GM4 said:Update
i dont like to wetsand with anything less than 2000 grit... thats right 2000 this way i have maximum control of how deep i go... yes it may take 2 more minutes to get to where i want to be, but there is hardly any risk of running into bare metal...
Never used the that app (IRAssistant) so I wouldn't know how. I have a Streamzap remote that has some programmable buttons so I just make a shortcut and assign it to that button. Another way would be to to use Girder.3N1GM4 said:and how do you get it on your remote... i got a remote i built (the reciever) and am using IRAssistant
huren said:nice mod dude , i like it . but ,
just wondering how long u think that the paint is going to stay keyd to your case with finishing your primer in 2000 ? and then painting .
the max you really want to key the surface with is at the highest grade 800 , even then you run the risk of fall off .
fair enough that you were wanting to obtain a nice finish in your paint , but you only need to finish in 400 , rub throughs are easly fixed with a very light dust coat to effected areas.
but as i said b4 , great mod dude =]
JEEVES/whohasmyname? said:400 are you nuts, Have you ever painted anything? And to let you know that paint is not going anywhere, you should have seen how many times he painted, sanded, painted, sanded. And he didnt sand the primer with 2000, just the paint. Oh and while he wasnt looking, i tried to scratch it and it didnt even scratch. So I think this paint job is ok, thanks
JEEVES
JEEVES
