Ok so I've been planning this for a while and only just got round to selecting most of the hardware to be used. Apologies for the poor phone camera pics at the moment!
The plan is to use this DFI motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813136056
to create a watercooled matx case based on this:
(Aplus Blockbuster BAW)
However the front panel will be entirely redesigned.
Here are some photos of the case frame that I will be modifying:
My current rig (quite old now, has had WC and lots of hardware swaps!):
I will be designing the case layout as soon as I can acquire some hardware to work with.
The radiators will be a front-mount 240mm and rear mount 120mm.
Most likely XSPC RS- series, the front being UV Blue.
This should provide enough cooling for a Phenom & 2900XT, which I have the following EK block for:
EK-FCR600
EK-FCR600
