Project H-R Server Case
Stratus
I have a short suspense to finish this mod on a Mountainmods Twice7 case so this log is going to go very quickly over the next three to four weeks. This is a theme case based on my hardware site called Hardware-Review.net.
Here's the parts list I've put together on this case. I'd like to also thank Silverstone, Logisys, Mountainmods.com, and Antec for their support and sponsorship on this project.
PARTS LIST
Hardware
Mobo: ASUS A8N-SLI Premium
CPU: AMD Athlon 64 3700 939
RAM: OCZ 2GB Gold XTC PC-3200
Vid card: BFG 7800GTX OC
PSU: Logisys PS550AC 550W acrylic PSU or Antec HE550 modular PSU (haven't decided yet if I want to go for cool looks or better performance)
Optical drive: Lite-On dual layer DVD burner (black, but will be stealthed)
Other parts
Case: Mountainmods Twice7
Case Wheels: Casters 4pack from Mountainmods
Windows: Custom etched windows from Mountainmods
Handles: Pro-line billet handles from MNPCTech http://www.mnpctech.com/MnpctechBillethandle.html
Front panel devices: Silverstone FP52 or FP54 (haven't decided)
Fans: Three Tri-cool blue LED 120mm fans from Antec, Two blue LED 80mm fans from Coolermaster
Fan Grills: Bell's custom H-R grills (2x80mm, 3x120mm)
I'm still working on this list, but here's a short run down of what I'm going to do with the case:
1. Get custom paint from Kikboxes.com (Black Chrome)
2. Annodize all thumbscrews, fan grills, case handles, power and reset buttons, and metal on casters a shiny chrome.
3. Cut side panels for custom etched windows (DONE)
4. Drill holes for handles and wheels (DONE)
There's more I need to do, but I'll update this log when I get everything finalized. =)
Please give me some inputs on this and what suggestions you have for the case. I am considering watercooling, but I dont have the dough to pay for what I want yet. That will probably be added later.
Here's one more update before I head to bed.
Here's a good shot of my custom etched windows
This is the top panel tapped up and measured to drill the holes for the case handles.
Tapped and measured to dremel out the side windows.
Tapped and measured to drill the holes for the casters.
Completed drilling holes for casters.
This shows how I measured the windows, but also has a square piece I'm cutting out that will be painted and cut in thirds to make panels to stealth my optical drives.
Completed cutting out windows and stealth drive panel
Shot of completed holes for casters
That's it for now. Tomorrow I need to file and smooth all my cuts and get everything send to Kikboxes.com to be painted. I can't wait to see it all painted and put together. Later. =)
I like it! Those are some big old holes to do with the dremel...how long did it take you to get through it and how many cutting disks did you have to use?
What is the diameter of your window holes?
The holes are 10 3/4" in diameter. They didn't take took long and I used 2.5 fiberglass cutting wheels. The cuts are also pretty smooth so filing and sanding shouldn't take very long. I'm looking to get the entire thing shipped out tonight to you for paint. *crossing fingers*
Well, good luck, I will be waiting and as soon as it shows up we will get started. The Powder Coat should take 3-5 days but I will try to push it along since you are in a hurry. :D
Not in too much of a hurry now. I shipped the case out yesterday, but I forgot to send you the optical bay drive. No worries though. I'm going to be waiting for the custom fan grills at least two weeks now so take your time on the paint. =)
UPDATE: Due to inavailability, I had to change the paint color to Charcoal Metallic. It still should look awesome though. =)
Here's a small update for ya. The powder coating on the chassis and side panels was completed last Friday and its now getting a little airbrushing today and tomorrow. The paint isn't complete yet because I had to wait for these custom grills below.
I shipped Kikboxes.com the following parts to paint the same color as the case:
- DVD burner cover
- PSU cover and back panel
- power and reset buttons
- activity LED covers
I received the case back from Kikboxes.com and everything looks awesome. Now I need to sleeve all the wiring, mount the etched windows, stealth all the front panel devices, mount wheels, install LCD, and install the hardware. Everything should be completed by this weekend. I'll keep you posted and take photos along the way. :D
Hey all, didn't do much work tonight on the case, but here's a few pics for you anyways. :D
Wired up the 5" LCD I got from Bellerphon at Gruntville.com. Pretty sweet eh?
Another quick pic of the entire LCD assembly
I took apart my fingerprint reader and this is what it looks like in the dark on my glass desk
Check out where I mounted the reader! It looks great under my MNPCTech handles (don't they look awesome powder coated?)
Here's the same shot without the flash so you can see the powder coat shine and the red glow from the fingerprint reader.
Both MNPCTech handles mounted to the top panel. Very sweet.
Last, but not least, here's a close-up of one of the handles
Tomorrow I should get everything put together, including the etched windows installed. Won't have the entire thing done until I get the fan grills back from getting powder coated, but I should have them by Friday.
Here's another quick update for you all. It contains tons of pics so 56K beware. =)
Back panel with unpainted I/O plate
Wheels installed
Inside of back panel with I/O plate
Mobo tray shot
full view of airbrushed logo
close-up of airbrushed logo
extreme close-up of airbrushed logo
front panel shot with airbrushed logo and optical drive cage installed
right side of case with optical drive bay cage and hard drive cage installed
another shot of right side of case
great shot of motherboard tray with standoffs installed
close-up of caster wheel installed
nice shot of top panel with MNPCTech handles
another shot of top panel
close-up of custom annodized thumb screws (I used 37 of these guys in this case)
mounting window with mounting tape
completed mounting window
installed window on side panel
left side panel with etched window installed
another shot of the left side panel
left side panel and some of front panel
nice shot of front and left panels in sunlight
same description as above photo
close-up of front panel in sunlight
back and right panel shot in sunlight
This weekend I'm going to install the LCD, front drive bays, power and reset buttons, and all the hardware. I'm not sure if I'll have time for cable management and sleeving, but we'll see. Please let comments and suggestions. I haven't had much feedback on this case and I like to hear what you guys think. Thanks!
http://www.hardware-review.net/mod/day3/1.jpg
http://www.hardware-review.net/mod/day3/2.jpg
Wheels installed
http://www.hardware-review.net/mod/day3/3.jpg
http://www.hardware-review.net/mod/day3/4.jpg
Mobo tray shot
http://www.hardware-review.net/mod/day3/5.jpg
http://www.hardware-review.net/mod/day3/6.jpg
http://www.hardware-review.net/mod/day3/7.jpg
http://www.hardware-review.net/mod/day3/8.jpg
http://www.hardware-review.net/mod/day3/9.jpg
http://www.hardware-review.net/mod/day3/10.jpg
http://www.hardware-review.net/mod/day3/11.jpg
http://www.hardware-review.net/mod/day3/12.jpg
http://www.hardware-review.net/mod/day3/13.jpg
http://www.hardware-review.net/mod/day3/14.jpg
http://www.hardware-review.net/mod/day3/15.jpg
http://www.hardware-review.net/mod/day3/16.jpg
http://www.hardware-review.net/mod/day3/17.jpg
http://www.hardware-review.net/mod/day3/18.jpg
http://www.hardware-review.net/mod/day3/19.jpg
http://www.hardware-review.net/mod/day3/20.jpg
http://www.hardware-review.net/mod/day3/21.jpg
http://www.hardware-review.net/mod/day3/22.jpg
http://www.hardware-review.net/mod/day3/23.jpg
http://www.hardware-review.net/mod/day3/24.jpg
http://www.hardware-review.net/mod/day3/25.jpg
Kick ass job mate, keep up the good work. :)
KikBox said:
Where are you mounting the LCD?
I'm thinking of mounting it on the top panel between the handles because its going to be sitting on the floor and it will be easier to view it from my chair. I was also thinking of putting it under my DVD burner, but it will take up two bays.
Thanks Leon2ky. My updates this weekend should be alot better. :)
Hey all, here's another small update. I got alot of work done on the wiring this weekend as well as the LCD mod. I'm actually creating an LCD console for the top of the case. I was originally going to just install the LCD directly on the top of the case, but a couple friends talked me out of it. Should have good pics of that today or tomorrow.
I also got my fan grills back from powder coating last night so I installed them. I was disappointed because my 80mm ones didn't fit. But, I talked with Bell this morning and we are going to send him an updated design that he can run through his magic machine again.
I'm also going to stealth the front panel drives when I get some time. Time is running down though because I'm having a few hiccups to deal with. I'm still scheduled to leave to Florida on June 1 so I really need to complete this mod by this weekend.
Here's what the powder coated fan grills look like. I kinda wish I had them done in a different color or I might even polish them to a mirror finish.
Close-up shot of the fan grills.
Very nice,
Can those handles support the hole case? Does the top panel bend at all?
I would have left the grills silver with a black or blue metal grill behind it, but thats just me! Great work!
Noni said:
Very nice,
The handles definitely can support the weight of the case and don't bend. I completely agreea bout the grills too. They need to stand out more for sure.
Sorry I haven't posted any new updates yet. I'm still waiting for the pics I took last weekend of the LCD console. I should have this project finished this weekend.
I've always wondered about the inside of these cases, can you take a picture of the insides when you can? How much room is in the HDD rack provided?
I took some pics earlier in the worklog if you'd like to see them. There's a good amount of room though. The HDD rack can handle around 5 HDs, but the ones on the bottom get real close to the power supply cables.
