Project: Greek Fire
Abadon
I HAVE A DREAM....AND EVERY MAN HAS A DREAM......
I think that's how the saying goes, basically it's the dream of a modern day gaming system (which will be out-dated within 5 minutes after this thing is done )
It's called Greek Fire. Why Greek? Because I'm Greek. Why fire? Well the design for the side panel will be a fireball (plus Greeks invented "Greek Fire" the first molotov cocktail)
What I plan for parts actual hardware
ASUS CROSSHAIR
AMD X2 5600+
2GB CORSAIR TWIN2X2048-6400C4D
2x BFG 8800 GTX (SLI)
SOUNDBLASTER XFi FATAL1TY
150 GB WD RAPTOR 10K RPM
750 GB SEAGATE BARRACUDA 7200 RPM
BFG PC 1000w PSU
What I plan for cooling
Swiftech APOGEE AM2 Waterblock
Danger Den DDC-12V Plus Pump
DD-8800GTX GPU Waterblock
as for the other main components, I still haven't decided, I might go with a DDCT-01 pump top, thermochill PA series RAD (3x120 but maybe 2x120 depending how I find to mount it in the case, as for the res, maybe a swiftech MCRES-Micro
This is an ongoing project, I will try to finish this ASAP, but like major power house PCs it's expensive, and I don have bills and insurances and other things to pay as well
The following images are of the case Lian Li PC-70 full tower after anodizing which set me back $70 CAD @ Progressive Anodizers (Warden and Bertrand in Toronto)
PS forgot to take images of the case pre-anodize but if you seen one LL case, you seen most of them ><
But the only prob is that I forgot to label the misc screws for assembly (should be by the end of the week, when the rivets come in) but since the threads are all different, I can try to piece it together :p
Sweet mod, hope it works out! And Greek power! (I'm greek too! :D )
This is the design I'm looking to get cut into the side panel
if the radiator ends up being too big to mount somewhere in the case, I will have to opt out and cut a traditional square style polygon and mount the rad/fan assembly on the window itself
