- Jun 26, 2002
Ok, so this is my first real project in a while... this time I'm actually going to be taking the step and trying my hand at watercooling. All I have ordered so far for this mod is the Lian Li PC - 7b Plus, the black one.
All I have so far for pictures in some concept stuff I've come up with.. this is going to a pretty drawn out project... seeing as how I'm just going to be buying stuff as I can get the money for it.
Well I guess I'll just show you guys what I'm planning to put in this... its pretty budgeted.. so price wise everything is going into the w/cing
List of stuff for the mod:
Lian Li Pc-7b Plus - Bought
Machined air intake plate 120mm
Modders Mesh
U Channel Trim Molding
Grommets
Swiftech STORM 1/2" Water-block
Danger Den Maze4 GPU Water Block - 1/2"
ThermoChill HE120.2
DD12V-D5 Pump
2- 120mm Fans, Not sure which ones yet.. still searching
Tubing and fittings,and the rest of the little stuff.
Well here are some concept pics of a few window ideas... still not sure which window I should stick with... this is still very much in planning phase and purchase phase.
My intial idea
Second thoughts I did a window to this on a case a long time ago.. liked it then.
I think this ones just plain... plain... T-T
This is going to be my cut for the top of the case where the rad goes.. No screws are going to be visisble on the actual top of the case...
Well tell me what you think so far....ideas, critisims, whatever... Thanks for looking...
Modders Mesh
Grommets
ThermoChill HE120.2
DD12V-D5 Pump
My intial idea
