cipher_nemo
- Apr 14, 2007
123
Thank you!The 1' x 1" x 1" sqaure tube sounds like a good plan. Don't forget to give it some ventilation. Some mesh or a few larger holes drilled above the transistors on the invnerters should work unless you don't plan to have them lit that often.
