paradoxblue
- Jan 4, 2006
So I've had my TT Soprano case now for about 3 months. been trying to think of things to do to it.
I al a huge storage whore. so I have a lot of hard drives. but I decided my new pc would be a pc only and that I would build a server soon to house all my hdd's in a huge wind tunnel of a case I can store downt he hall so I donthave to hear the damnt hing lol but that project is to come later.
I Want to water cool my pc soon. the specs of the pc are:
- Opty 170 OC to 2.4ghz
- A8N-SLI deluxe mobo
- 7800GT CO vid card
- 120gig SATA 7200 rpm hdd (may upgrade to faster?)
- 1 gig ocz ram
- 620 watt modular psu
Ok so that takes up a little space. plus the hard drive cage. and the disk cages. My DVD-rom/burner is an external usb one. and im very happy with it. love this lil guy
lol
so the cages. to me. are useless.. hmm what to do? ok so bellow is the first part of the project. i did not take a whole hell of a lot of pictures. but you should get the jist
Pic one:
PC stripped down and all my tools on my gheto work bench in my empty basement. yay. least i have a good place to paint, hot and dry down there to
Larger: http://www.takagari.com/Gallerys/PC/PICT0085.JPG
Pic Two
After drilling out to many fawkin rivets. Theres more space!!! and a mess. oh and the paint job is fooked.
o well more reason to repaint right
Larger: http://www.takagari.com/Gallerys/PC/PICT0086.JPG
Pic Three
I decided I would mount my hdd to the bottom of the case for now. later I plan to have it else where to make more room. I have the location picked out but am tryin to find some nice brackets to hold the drives up a bit before i moune them there. This is a pic of a piece of paper screwed to the hdd using the bottom mounts. great way to makea template.
Larger: http://www.takagari.com/Gallerys/PC/PICT0087.JPG
Pic four:
Case all put back togethor. told you i skipped many a step. but now look at that huge void, lotsa room to mount a res, pump, and radiator. hehe
once i get all my needed psu tools in. ill be even happier. WOOT!!
Larger: http://www.takagari.com/Gallerys/PC/PICT0089.JPG
One more:
Larger: http://www.takagari.com/Gallerys/PC/PICT0088.JPG
Pic 5:
This is how my hard drives are temp setup. GHETTO lmao. the hole in the top from where ports use to be was jsut right for running cables. with my cool breeze from the window. should keep em ok. i can justt ouch them to check if there to hot. good so far, lil warm but its only temporary.
Larger: http://www.takagari.com/Gallerys/PC/PICT0090.JPG
- 1 gig ocz ram
Pic one:
Pic Two
Pic Three
Pic four:
One more:
Pic 5:
