After admiring Craigbru's SG01 Coolit Freezone mod - I decided to install a Coolit Eliminator TEC CPU cooler in my Fragbox
Summary of installation modifications:
The only other problem I ran into was the power connector on my 8800GTX is blocked by one of the TEC chillers. I was able to mod the PCI-E power connector to get it to fit but did not power up the system again due to the leak.
hopefully I can get this resolved with Coolit, so that I can really test this thing out properly!
- Removed the HD cage from the Fragbox to make room for the Coolit Eliminator
- Re-located Coolit pump 1/2" lower
- Relocated HDD to 3 1/2 bay
- Connected Coolit Elininator fan to SYS fan connector on Motherboard (for auto speed control)
