Almost all my pieces have arrived so it's time to start the worklog on FFF: The Form Follows Function project. Although it's not going to be a ghetto build, it's not designed to impress the ladies at the LAN party. It's a system built for as much quiet as can be reasonably expected. The key to the build is big fans moving slowly to keep the noise down while pushing through enough air. And I'm throwing in some lights because everyone needs a little bling!
So the first thing I did was remove all the stupid junk from my new Xclio A380. The side fan got ripped out and I'm keeping it as a spare as I'm aware that the Xclio 25cm fans have the half life of Darmstadtium 267:
Then I removed all of the incredibly ignorant sheet metal plunked right in path of 100% of the airflow from the front 25cm fan. (This pic is not from my build but identical):
Not only is there a whole barely perforated HD stack, but there is an entire cover for what seems was (at one point in development) a 120mm or so fan! When they replaced the 120 with the 250 they left the cover alone. So of the full 250mm diameter, almost 2/3rds of it is blowing onto solid metal. What's the point of a huge fan blowing onto a small metal colander? Xclio's engineers should have their heads examined!
So all this crap got ripped out and this is what the case looks like now:
There are still some more very unconventional airflow mods coming!
I'll keep you posted as I'm hoping to get this rig finished this weekend (knock on my wooden head!)
