Project Exometry: An Endeavour on a Functional Prototype
Thanks for spending the time reading all of that! I appreciate every critiques or comments, so don't be afraid to do so!
Love the case, love the idea, and love the layout. But i figured something right away.
You put the graphics card the same way as the A4-SFX, but you did a big improvement lowering the gpu slot, that way height won't be an issue
I want to get the A4-SFX, and i got a 980ti kinping, width is not an issue, but height...
If it fits is going to be a miracle, even when this card is just 0.5 inches wider than reference, but is a lot taller...
So if i can't fit my gpu into Dan's case, i'm going with you boy!
I'm not even aware cards that height exist! 0.0
It might be a coincidence, but I didn't think that adding that much leeway to the GPU chamber can be more of a benefit other than airflow. Count yourself lucky!
