Darth_Fluffy
- Aug 15, 2004
Just a bit of advice, you might want to mod your PSU. The higher wattage TruePowers have an El-Cheapo temeprature sensing fan controller, which inevitably fails, causing the fans not to work, the power supply overheat.. and well, incinerate. Mine is a 480 TP, and the fourth time I used it, I noticed that it took a full minute before the fans in it started working. People on newegg are also complaining that these PSU units blow up on them. The thing you do is remove the cover (who cares about the warranty?!). You get rid of the fans, as they are uneeringly loud if you run them at 12V all the time. Replace the fans with quieter fans of your choice, and hook them up to a molex rail. Don't use the "FAN ONLY!" rail, as it's also routed from the El-Cheapo fan controller. I imagine my fan controller failed a long time ago, but my Panaflos keep cooling the PSU. I also painted the inside black and put a plexiglass PSU cover
