beginnermodder213
- Jul 5, 2005
Hey, this is my first mod i've ever done any first time using a dremel, take a look at what I have so far and im open to tips and suggestions because i dont know much about modding.
I've bought some plexi glass and im about to install it, im still working on sanding the edges to look smooth if anyone has tips on how to do it good it would be appreicated.
I am planning to remove the green cover, replace it with 2 LED fans, and also add a temperature monitor in the front of the case.
I plan to paint the box with some automotive grade/touch up spray paint.
any tips or suggestions would be awesome.
