Project DK1 [100% home made case]
DIDAC
Hi guys,
this is my new SFFS completely homemade.
Cost of materials about 40 Euro (excluding wood...)
internal dimension (cm): 16 x 23,7 x 24,4 (9,3 litres)
external alluminium dimensio (cm):16,6 x 24,3 x 25 (10,1 litres)
external wood dimension (cm): 19 x 26,5 x 26,8 (13,5 littres)
♦ Asrock H77M-ITX
♦ i5 3570 with CM GeminII M4 FAN-> PULL
♦ 2x2GB KINGSTON
♦ MSI GTX 660 OC TFIII
♦ Silverstone sfx 450w ST45SF
♦ two top fan Noctua redux NF-S12B
♦ SSD samsung 840 120GB
♦ HD 3,5" WD RED 3TB
Red led on top are disk access.
LinX
GRID 2
Very nice! I like the aluminum frame. I'd always wanted to do something like that.
Thank you guys.
Is not to difficult to do aluminium frame, you can see all pictures to understand which is made.
If you need any help, contact me ;)
WiSK i'm happy that you write here, I have a question for you: replace fan on Silverstone sfx 450w ST45SF : My DK1 consumes 200 watt max, I would change the stock fan on ST45SF and put Noctua A9x14. What do you think about this idea? Or better the BlackSilent Pro?
I know that you replaced stock fan, I saw your pictures. :D
thank you :)
bye
I'm afraid the Noctua 92mm won't fit in the bronze ST45SF. In the gold model, you can move the plug easily, but in the bronze one there are other parts in the way. The BlackSilent Pro PC-P has the right dimensions and adequate voltage-rpm profile.
For BlackSilent Pro PC-P: 23 Euro
For Silverstone SST-ST30SF (with fanless feature): 50 Euro
My pc reaches 200 watt max.
I Think taht it would be better buy ST30SF.
They are strips of parquet raw, but they are very smooth in one face.
I used sandpaper but not in the face that you can see.
