Hi everyone!
Now it is time for a tiny update on the project to show that the project moves.
I thought only certain why I have not done much the last of my project,
But now it's fine and I have started to fix some of the case.
I have inserted the power connector for PSUn and made ​​holes for the radiator to get air.
Here is the hole for the radiator,
I did see one problem when i did get the radiator in the case,
But it wasent a to hard problem to fix,
The hole for the radiator will be filled with mech to do that completely matches the Case, but I have trouble finding any mech that fits to hold the front and rear.
So if you know somewhere where you can get the mech to hold on 3mm, I am eternally grateful.
This was a small update but have to some that something happens in all cases.
//S.Jr
//S.Jr
