Project: Diabolo
Luciel
Hi Everyone!
So, this time round it won´t be a case revival or a "Mod in a Week" project, mainly because Cooler Master has decided I should have a HAF X and well, I kind of want to take my time with such a nice case :D!
Now, I am useless at google sketch and that kind of software that you guys use, not to mention drawing! So I will try to explain the concept of project Diabolo.
If any of you saw my Fallout Cause project (http://www.neonit.net/) you´ll know that, more than anything else, I enjoy painting, and with my previous project (Acid Burn) it was a pretty simple paint scheme, no matter how detailed it was and I feel like playing with shades and effects again so... I´m going to (or try to) turn this gorgeous HAF X in to a demon, (the fact I played through Doom 3 and it´s expansion again the other day ... may have something to do with it!
So, I will be using foam and epoxy (with internal reinforcing) to build 2 massive horns that will go through the lenght of the top of the case, depending on how these come out, I might also add a pointed tail. Aside from this, I will be modifying the body (it´s going to hurt bashing it in) and adding "skin deformations" to give it that tough demon skin look.
Paint wise, black, with dark red/purple skin tones, and bright-ish red details to accentuate irregularities in the skin. For the horns, I´m thinking white-ish cream with a dark brown dry brush touch, or I may go with dark colours like the rest of the case, we shall see!
Hardware wise, the wonderfull people at Cooler Master (I´m looking at you Gert!) have also sent me an awesome 80+ 1000w PSU. I will be using an ASUS P8P67 Sabertooth (I´ve chosen this mobo because of it´s thermal armor, which I can modify to match the design), with an Intel i5 2500k. 2x Asus ENGTX 275, a Creative X-Fi Titanium Fatality, 3x Seagate Barracuda 750Gb S-ATA2 drives and a Pioneer cd/dvd combo drive.
Other hardware like fan controllers, memory card readers and so forth I will add as I see fit if I can put them in to the design.
Right, for those of you who saw my week in a mod project (acid burn) you might remember my work place was a complete mess for several reasons I won´t go in. So, first thing´s first, let´s sort this place out!!!!!!
Quite a mess huh? I should also mention it´s currently 37c... and rather humid...ugh!
Yup that´s my old Fallout Cause sitting there waiting to be either sold or re-purposed :/ and of course, the goodies from CM!
Right so, assorted cables and accesories, sorted!
Assorted Hardware, sorted!
Bits and bobs, sorted!
Tools, sorted!
Workbench, sorted!
I can´t stress it enough, Thanks CM!
Let´s start unpacking...
And that´s it for now, tomorrow I pick up the materials needed to start the transformation of the case!
You lucky dog! I need to show off some modding skills so i get free shit.
As for your work, it's great and im watching to see how this one will come out. Awesome of course.
Thanks! I hope so, I´ve never used epoxy before so it´s going to be quite the experience (specially the apparently awfull sanding process that epoxy requires).
