Project: Devil's Dark Side
NJHC
I have log on a couple other sites and forgot about [H].
So let's begin.
So here is a list of parts for this build.
Computer:
Mobo: EVGA X58 SLI
CPU: Intel I7 920
Memory: 6 GB of Corsair Dominators Tri-chanel
PSU: 1200w Topower Powertrain.
GPU: 2x EVGA GTX 285's
HD: 2x WD Raptors: Raid 0, 1x WD 640
DVD: LG DVD-RW
Case:
Rocketfish
Fan Controller: Sunbeam Rhoubus
Cooling (Liquid):
Loop 1:
1x Feser X-changer 360 radiator
3x Feser Shrouds
1x MCP655 Pump
1x EK D5 top Rev.2
1x Koolance 80mm Res.
1x Koolance CPU-350 CPU block
Feser UV blue coolant
Feser UV Blue 1/2" Tubing
Loop 2:
1x Feser X-changer 240 radiator
2x Feser shrouds
1x MCP655 Pump
1x EK D5 top Rev.2
2x Koolance GTX285 GPU blocks (Thanks zlojack)
2x Koolancs SLI compresion fittings.
Both loops locked with compression fittings
A bunch of Yate loon fans for the case and LC loops.
Misc. stuff that will be used to mod the case will be posted when I get to that part of the build.
Stay tuned.
NJHC
First batch of parts.
Some more parts.
And what might this be?
One of the feet for the case. With one of the rads on the bottom I need to give the case a lift for air flow.
NJHC
More came today.
Rad grill's, some fans and the HDD mounts.
One of the grill's.
The HDD mounts.
Some pics of the case. Sorry for the crappy pics.
Now I can start surgery on the case.
IndyGSX
sub'ed simply because I want to see another 'fish get hacked.
I own 3 of them ;)
nate
NJHC
I own 3 of them ;)
nate
This case has alot of headroom for modding. I've seen some reaaly nice mods and some REAL bad ones as well.
NJHC
Popped the top tonight.
and....
Started to mark the inside for the next round. Just need the #$%#@ res's.
NJHC
Haven't posted any progress in a while. Partly due to I've been swamped with work.
Some of you wanted to know what I was going to do with 20mm fans. Well here you go. With 5 fans on the rads bringing air into the case I needed to add some more exhaust fans to even things out.
NJHC
Here are some updated pics. I'll have more tomorrow.
And a big shout out to my build team.
Nice work so far! Looking forward to more updates.
This has given me a great idea for watercooling in this case.
What did you use to mount those pumps? What did you cut the top for the radgrill with?
NJHC
Thanks guys....
I used a Dremel for radgrill cut outs. The mount for the pumps come with the EK pump tops. I Just bolted them together.
This is far from finished. I'm still making some cuts to the case.
I will post more pics in a day or so.
Thanks guys....
Length and diameter of the bolts?
NJHC
Did the final fitting in the case. Next prep for some color.(Excuse the finger prints & crappy photo skills.)
SirKronan
Very nice so far! Subscribed for sure. I've done some less elaborite simple mods on mine, and it's been a fun case to work with. Lots of room, and good cooling with minimal effort and money.
Vegasr
Looks awesome so far. I have this Rocketfish case still NIB in my closet, waiting for some mods. This might be the perfect blueprint. Congrats.
NJHC
Since I've been busy in life I work on what I can. A couple weeks ago I started to paint what I could. So here is a sneek peek. I have some other parts painted but here you can see what is to come.
I decided only to paint the bare/silver aluminum and to not paint the brushed black finish on the case already. So here is the door.
Let me know what you think so far.
Thanks
I really need to improve my photo taking skills.
NJHC
Thanks.
I hope I can show what can really be done with this case. I have seen some nice mods but wanted to go little beyond.
holinger
is it possible to get rid of the rocketfish logo? Looking great, keep up the good work.
rally9x
Rocketfish is a Best Buy house brand, so this case was only sold their and has since gone out of stock. Their are Lian Li cases that are very close though.
NJHC
As promised... some updated pics.
Here are those case feet in action now.
What do you think. I think they turned out pretty good.
Some more of the chasis.
NJHC
Been getting busy.
Here are some recent pics. Just have to do some final sleeving and then get this running.
What do you think so far?
Gorgeous. I wish I had those kind of painting abilities.
How far from the back did you mount you radiator grill?
Are both rads pulling? Did you make those feet yourself?
Sorry for all of the questions, but your work is really good.
ekuest
very nice. i like that look a lot. i kinda wanna do a red and white but i dont think i can find a mobo to work with it...
