NukeULater
- Sep 12, 2006
I had this old Dell XPS t600r case sitting on my desk and it looked like a perfect modding case.
The case is pastic so it was easy to cut. The dell logo is going to be covered with bondo so you will never see it.
Anyway, pics!
The case has been hacked up already so I had to cut around the hole. I used a jigsaw for the main part, and a dremel for the clean up.
The blue 4 inch CCl's are just for testing, they will be replaced with orange or red CCL's
Next, comes the mesh for the front bezel.
Anyway, pics!
