Chaos_Being
- Oct 26, 2005
Well, it seems like it's that time of year again...time for those who are obsessed with upgrading and tweaking their pc to do a bit of re-building (namely, me
Nearly a year ago I posted up a project log for the creation of three of my current pc's, which can be found here: http://www.ocforums.com/showthread.php?t=459291. I am currently re-visiting my "Cyborgmind" build, with some new case mods and some new hardware. The reasons are twofold. One, (the primary reason,) is that I wanted to build my sister a pc. She doesn't have overly demanding computational needs, but she was in sore need of an upgrade (her computer was probably around 10 years old, eek!) So, I planned to do some hardware migration- my computer parts (cpu, ram, motherboard) would go into my wife's pc along with a few new parts, and the guts of my wife's pc would become my sister's pc. The second reason? I like upgrading!
Cyborgmind: Duo is ideally going to be a multi-stage process. I've already begun my work (which I am going to chronicle shortly,) and I am hoping to complete stage one within a week or so. Stage Two, and possibly Stage Three, are mostly further aesthetic mods and things that I want to do, but aren't necessary for my basic goals and pc functionality, so they will "happen when they happen," so to say.
Stage One will of course consist of the hardware upgrades. I'm moving back to Intel, and will now be using an e6600, Abit QuadGT, and 2gb of Geil PC6400. I will still be using my 8800gtx and PCP&C Quad Silencer 750w. I will also be furthering my black and green theme, by painting the inside of my case black, and adding some new green highlights. I also plan to go back and clearcoat some of the pieces that are already green, as the neon green paint I used has a powdery texture that I've never completely liked. I want a smooth, glossy finish instead. Lastly, my goal with this new build is max silence and max performance using air. I had initially planned on watercooling, but as usual, the funding to "do it right" wasn't there (when I finally get into watercooling, I don't want to do a cheapie setup.) So, I am challenging myself by trying to wring the last bit of performance out of aircooling while making my case even quieter than before. In particular, I am going from a four-fan layered intake setup back down to two fans. I used four fans before because I found that two fans all the way in the front created hot spots of air inside the case. To get around this problem, I will be shifting the intake fans back further into the case, and making sound-insulated intake ducts for them. If my cpu temps end up being unsatisfactory, then I will be lapping my cpu & heatsink.
Stages 2 and 3 may be partially exclusive. The part of Stage Two that definitely is not involves stenciling. I want to frost a circuitry design into two of the window panels on the side of my case, and I may also do similar circuity stenciling to the inside of the case, using UV green paint. Stage Two may also involve installing an HR-03 Plus on my 8800gtx, and fabricating a plexiglas duct that would connect to the lower intake fan. The intake fan would blow air into the plexiglas box, across the HR-03 Plus, and out the open PCI slots. I initially came up with the idea when I had thought about running x1900 crossfire, as a way to silence the incredibly loud heatsinks on those cards. In fact, here is the mockup I drew for that- the idea would be the same, except that there would of course only be one card.
The beauty of this setup is that not only should I get better temps on my video card, I would also be eliminating two fans! In addition to the normal stock heatsink, I have been running a quiet slot blower underneath to help exhaust the air that would normally leak out of the slits in the heatsink shroud.
Stage 3 would be to finally go with watercooling. I had been eyeing parts such as the 3x120mm Swiftech rad, either the D5 for the DDC with modded top, D-tek Fuzion, etc. Who knows when I'll get around to doing this, but I definitely do want to try it out sometime
So far over the past week, I have already completed my wife's pc and my sister's pc. I just started working on Cybormind: Duo over the past two days, and I finally made some real progress today. However, the full spread of pics are going to have to wait, as I am getting sleepy...
For now, here are the pics of all the parts I ordered (the Scythe Silent Drive came afterwards, hence it's solitary picture.) I will get some progress pictures up tomorrow
GOODNIGHT!
GOODNIGHT!
