- Mar 21, 2007
Sometime before Christmas this past year I decided that its come time to freshen up my PC build a bit and finaly take the jump over to the world of liquid cooling. The folowing is some pics etc. Unfortunantly when I get to building I typicaly forget to take pics
I'll share what I have and explain the project as we go.
Basicaly I started with a typical Antec 900 build with typical Antec 900 wire managment as seen here.
I started work with the goal of cleaning up the wireing and adding watercooling to the box for both CPU and VGA without spending huge amounts of cash.
Here we have a couple shots of the case after cutting holes to re-route wiring behind the mb tray and after priming and painting. I chose to go with a metalic black as it has some bling with out being too over the top.
All in all it came out not too bad, especialy for being done with a Rattle Can in my garage.
After getting it all cut, debured and painted I re-assembled the machine, adding a Danger Den TDX, Swiftech Pump, XSPC laing Res Top and a Swiftech MCR-320. I'll be adding VGA cooling down the line as I will more than likely be performing a stepup in the next couple of days when the 285gtx arrives.
Now I hear some of you asking... where the hell is the MCR-320?? Great question, stuffing it in this case is about imposible without making a major hackjob and relocating components, which I really did not want to do, so.....
What you see here is a rough cut wood stand that allows the rad and 3 120mm fans to sit comfortably under the case. I took the front fans and used them on the rad and replaced the one on the drive bay with one that has no LEDs. This is where the project sits today.
Things that will be happening in the next few weeks
1)Step up to GTX285. This will alow simpler wire managment due to the need for only 2 6pins rather than 1 6pin and 1 8pin. Currently I need an adapter for the 8, which makes a mess.
2)Get the sides on the case.
3)Finish out the rest of the Rad Base. This will be the primary focus of the rest of this log. Basicaly the goal is to have the base match the rest of the case so in the long run it just looks like a really tall 900. I just received a 2x3 sheet of perferated steel from a freind and will be using that for grills as well as to cover the face of the base. It should match the front mesh quite nicely when finished.
