Project: Centurion 5 - Redux
Mike_Check
Hey guys!
Long time reader for the [H] very, very infrequent poster. Thought I'd try my hand at a worklog to see what all the fuss is about
First thing you'll notice is this worklog is a 'Redux', that is I am re-modding a previously modded case. Originally I modded the case because I wanted a more quiet computer as it sat about half a meter away from my bed. A quick (and by 'quick' I of course mean 'length and in-depth') perusal of Silentpcreview.com and around the 'Tubes I found out what needed to be done so off I set on my first modding adventure.
Bearing in mind this was it waaay back ago when I had limited tools (a drill) and little experience (I was like... 16):
Dodgily mounting a 120mm fan in an 80mm fan spot.
(Yes, that's blu-tack)
The whole system. Notice the cutout at the top for PSU wire routing. Also a 120mm blowhole was added.
Blowhole up close. I was actually pretty proud of how that turned out.
Now; onto the Redux...
This Chirstmas season I got a lovely, shiny and cordless Dremel from my parents. Any half serious case-modder knows that the number 1 tool by far is a Dremel; so off to work I went cleaning up my previous endevours:
The back grill was cleaned to a proper fit.
I cut out an actual hole for the new 120mm intake and created actual mounts (bye bye Blu-tack!)
I also cleaned up and added a few more cable routing hole now I have more control over what and where I can cut.
PCI-X Connector:
Picked up a few fans a mate was getting rid off for the new look (blue is, like, totally last year):
Things to note:
- I don't actually know what system I'm putting in this...
- You'll notice there is no 3.5" bays. I took them out in favour of the 120mm intake.
- Hard Drive(s) get suspended with elastic in the 5.25" bays to eliminate all HDD noise
Things to be done:
- Carbon fiber vinyl (I'm not telling where though!)
- Make ducts for front intake
- Finish off HDD suspension in 5.25" bays
- Finish off cable management cleaning.
That's it for now.
Sister's 21st this weekend so gotta go up and see the rents. Next update will be next week sometime.
Until then,
Thanks for reading and criticism/comments are more than welcome.
M
