Hey all,
I've posted a few pics here and there of my rig that's currently under construction by Misha's craftsmen at AVAdirect. A couple of peeps have requested more pics and 411 so I decided to start this thread to share some of my joy of having this rig built.
I started this project in early December actually, and spent a lot of time here researching the various system integrators and ultimately decided on AVAdirect for many of the same reasons that others have: great value, enormous choices, and a solid reputation for building highly customized solutions.
After deciding on AVA, Misha and I communicated often to narrow down my conceptual ideas and enthusiastically encouraged me to really customize the rig. The design changed several times as new ideas were created and some new products came on the market.
After I had settled on the Silverstone TJ07 case as the starting point (because I wanted a totally watercooled solution) I was inpired by Theorie's rig on these boards. One picture in particular lit the fuse for me. Theorie showed his rig underway with the top vent removed and his watercooled GPU on top. I had just discovered EK's FC8800 block for the 8800GTX and loved the looks of it and thought it had to be highlighted in the rig. So the basic concept of the case is the top window that shows off the EK block on the 8800GTX as well as a Raptor X. Everything else sort of followed that basic premise.
My first home computer was an IBM PCjr, anyone remember that? So I've been at it for a while and have the means to build the ultimate rig.
Here are the main components:
2 separate loops for
Now for the pics:
My original photoshop'd concept and the case exterior as built
Here's some action shots from the shop at AVA:
Here's a detail of the top window:
Here's the mainboard with the waterblocks installed:
And finally, a shot of the 8800's in place and the start of the plumbing job:
That's where we are right now (March 15, 2007). Misha sent the last pic this morning and has kept me informed all along the way.
If you are looking for a totally customized extreme gaming solution and know exactly what you want, but don't want the hassle of building it yourself and want someone to back it up with a strong warranty, I don't know anyone else that can do it.
AVA rox!
More pics as the build progresses.
- Silverstone TJ07 - BTX window on right side with custom window on top
- ASUS Striker Extreme mobo
- Intel QX6700
- 4gb OCZ FlexXLC RAM 9200
- (2) eVGA 8800GTX ACS3 in SLI
- (1) Raptor X
- (2) Raptor 150 gb HD's
- (2) Seagate 750 gb HD's
- LiteOn 20X DVD-RW
- PCP&C 1kw quad PSU
- CPU, GPU, NB
- RAM, MOSFETs, SB
- BIX 360 Rad for 1.
- Swiftech 80 Rad for 2.
- Swiftech MCP 655 pump for 1.
- Alphacool DDC Ultra pump for 2.
- D-Tek Fuzion for CPU
- EK FC8800 for GPU
- EK blocks for Striker NB, SB and MOSFETs
- OCZ integrated waterblocks on RAM
- Cape Coolplex 250 res for 1.
- ALphacool slot res for 2.
- Tygon tubing throughout, 1/2" 3/8" and 1/4" as req.
- Swissflow SF800 flow meters and temperature probes
- Alphacool LCD display
- Silverstone drive bay adapter
- BigNG T-balancer with analog and digital extension sets
- Carbon reflex sleeving on major cabling
- Bulgin switches on front panel
- Some UV lighting and LEDs throughout
Now for the pics:
AVA rox!
