The BlueBerry Muffin
Sponsored by:
Special thanks goes out to Freddy from Highflow for his amazing work and quick customer service
Sponsored by:
The Background
I get inspired rather easily... My last build was thought up of while i was drinking a very refreshing and fresh orange+sanguine juice. This build is no different. Once a week i treat myself to a blueberry muffin, and one day while i had taken a big bite out of it, i found myself, looking at the colours, and thinking, wow.... i want a computer this colour. Hence, The BlueBerry Muffin is born.The Hardware
- Asus Rampage II Gene- Intel Core i7 920
- Sapphire 6870
- 2TB HDD + INTEL 510 series 120GB SSD
- 6GB DDR3 1600Mhz Dominators
- Silverstone Strider 750w
- Lian Li V351
The Cooling
- Ek Coolstream 240
- EK 6870 FC Blcok Nickel
- EK 6870 Backplate
- MIPS ASUS GENE Series Fusion-Block
- 4xCoolermaster Excaliburs
- Koolance RP 402x2
- EK Supreme HF Plexi CPU Block
- 2 x Laing DDC-1Plus MCP355 12V
- EK Compressions 10MM (3/8 ID - 1/2 OD)
- Koolance 10MM (3/8) 90 degree rotary
The Accessories
- Coollaboratory Liquid Ultra- Aqua-Computer Temperature Sensor Inline
- Koolance INS-FM17 Coolant Flow Meter & Adapter Board INS-FM17
- 240 Rad Stand
- Nexus Extra ventilation PCI Brackets
- 19MM Bulgin Silver / Orange LED
- NZXT 24x White LED Sleeve
- PCI bracket with 2x G1/4
- Tube Cutter 10-40mm
Case got back from Powder Coaters yesterday! So here it goes...
The case came out exactly the colour i wanted, but unfortunately, some parts of the powdercoating wasnt great. The were a few discrepancies, enar the areas where he needed to bolt the case down, but luckily for me, none of those areas show!
I cut out the bottom of the HDD support so that my GPU+Block could fit.
The white Pop Rivets were horrible to work with, they kept flaking, and i ahd to keep redoing them :/ must of gone through like 100! eventually i got them all in place and with minimum destruction.
And thats the Lian Li V351B (B for Beige
Tomorrow, im taking pictures of parts
