Project: Black Avenger
Jbroad572
Here's what I got so far:
Case: Lian Li PCV2000B
Water Cooling:
-MCP600
-MCW6002-64
-MCW50
-Dual Heatercore
-CoolerMaster 120mm fans
Video: BFG 6800GT
CPU: AMD64 3400+ (Clawhammer CG)
Mobo: DFI Lanparty
PSU: Fortron 530
I haven't thought of a name yet, but I'm thinking about "Black Avenger".... sound good?
Anyways, I originally had the V1000B, but because of Blu3 I sold it and bought the V2000B.
img]http://broadways5th.com/scgi-bin/The%20Black%20Avenger/V2000Binsude.JPG[/img]
I orignally wanted a window just like his, but had the idea 2 make 2 seperate windows and then I actually saw how I wanted to do it on the same post, so I went with that. I was scared to cut it out at first, but figured, wth! If everyone else can do it so can I. I had a cheap dremel and a jigsaw with a 24tpi blade.
My first objective was to cut the window out, so to start a whole I used the dremel reject and the reinforced cutting discs. Well, I got just that accomplished and nothing else. The dremel made a weird noise and the disc went flying and here is the end result of that (no more using cheap dremel wannabes).
Needless to say after that I put the panel away for the night and put together my new exercise bike
:D
So, the next day comes along and I'm like I've already got a hole in the panel, so I can't quit now, so while a friend was over I clamped it all down and put the jig blade in the hole and expected the worse, but to my surprise that was the easiest thing in the world. I absolutely love using a jig and don't want to have to use a dremel to do this kind of work. I was done in about 30 minutes, because I took little breaks to entertain a few friends. Here are a few pics.....
At one of these pics, I regretted making them square and wish I would have rounded the corners, but too late now.
Next is the watercooling. I was in the process of leak testing, but I have some nasty stuff in my loop that looks like ..... welll uhhh... look for yourself. Not sure where it came from, but I'm guessing the heatercore. I did buy it used :(.
So, now I need to untape the panel, file down the edges, and continue with my leak test with my WC setup.
I am going to pick up my fans, CCFL lights, right now. I was thinking about doing a blue/white theme in the case. Maybe have 1 color on the top and 1 on the bottom. Not sure yet. Suggestions are welcome.
This is the beginning so far.
Here is the window installed without tape:
Still have to file it all down though.
The_Dark_Hacker said:
definatly file down the edges. they are a little uneven. looks good though. cant wait to see more
I love the sig :p
I'm working on having a quad 120mm grill made out of stainless steel (similar to the evo 120.3 grill
for the top of the case.
Thinking about it, I think if the grill were black, that'd be nice with some aluminum fans under it or some lit up fans or might just leave it stainless steel. I think either will look very nice.
a quad 120mm fan grill. havent seen that before. ya my sig is great. where is the fan grill going to go, where you cut the bottom hole?
Like so....
That is a V1000 I have a V2000, trust me it will fit :D
I just posted as an example of what I was shooting for.
OMG FILE DOWN THOSE EDGES!!!!!! sorry couldnt resist ;)
looks awesome, i cant wait to see the quad 120mm fans lol
ya quad 120mm fans is going to be awesome. after looking at the demnsion it can fit. i hope you use some quite ones or you will go deaf
it is your duty as a modder to file down those edges! lol i am just kidding but it will def look unique, good luck
If one more person mentions the filing....... :p
I will get it done. I have to wait for a few $$$ to come in so I can buy them.
I just know some smart a$% is going to mention it once again after this post.... Go ahead, I know you want to...
Well, I've decided to go with white CCFL's in the case. I wanted to originally have both blue and white in the case shining somehow, but the white is just too bright. I also want to have my UV lights somewhere in the case. close to my mobo. I am going to mix my water with Deep blue dye-lite and VW anti-freeze to achieve a darker blue/teal color.
I have 2 white led fans and 1 blue one. I think I might replace my case fans with those and go with some aluminum one for the top of the case. It would look nice under a black grille, don't ya think?
Still brainstorming though.
Very nice so far... I love these mods for the new Lian-Li cases...
BlackAvengers is the name of my Fantasy Football Team... Black is my last name, and the Avengers in my favorite Arena Football team.
Here is the panel all filed down.... 3.5 hours later... goodness.
Still not as smooth as I would like it and where I made the whole with the dremel at the very top, it took some of the paint off of the panel as you can see. Got a few other places where could use some touch up paint, but I think I will just leave it be.
Tomorrow I will be removing the hard drive racks along the bottom and debating on whether I want to take out the divider plate. I read it is just fine (stability wise) without it.
Thanks for all the compliments so far. I guess not too bad for a very first timer, eh? I know it could be better, but I feel it's going well, for a noob who didn't even know what a jigsaw or dremel did :eek:
Added leak testing picture. I will probably be leak testing for awhile. Won't be installing until the case is finished, lol, so it might be a week or so. Plus, I am still waiting for 1/2" barbs for the MCW50 and have to make a shroud.
Here are some better pics of the window and the cages have been removed. Still debating on moving the divider. Until, I get an idea of what I can do without it there, I'll leave it there.
