So this is the beginning of my next case mod, of a case that I bought for $1.25 at a garage sale. The idea is that I want to make a case with a black and green color scheme (case 'frame' will be painted lime green, exterior of case will be gloss black) and I wanted to load it with Green LED fans....and I want to have a biohazard symbol cut into one side panel, and put clear plexiglass behind the cut, and then get lime green cold cathodes to light up with more green. I am also planning on putting some sort of 4-6" LCD in the front where my 5.25" IDE bays are, and also a small monochrome LCD in the 3.5" bay. Anyways, This is where I will be posting up all my pics and progress as I move along... I just started this past weekend, cutting my first fan holes and such...so here it goes!
in my stupidity, I didn't take pics of the case as it was totally unmodded...but I have some pics of my first steps in the mod process.
This is the case after I had disassembled it
I want to somehow figure out how to put
I also decided that I was going to throw a second PSU in there to power fans and accessories
(I will look somewheres for a pic of the original..i KNOW that i took some!)
So my first idea was to mod 3x 92mm Green LED fans onto the top of the case...
so a-measuring I go...
There is an opening in the top of the case right where I drew my little rectangle for the fans to fit into...and suprisingly, 3 92's fit in there about perfectly!
This is an old AT style case i think...and my motherboard I want to buy will not fit in there currently...so I used an old b0rked mobo of the same dimensions to mark off where I need to do some drilling...
I decided that since I Was going to have so many accessories in this case, I needed a second PSU, so I figured that I could just remove the HDD mounting cage in the top of the case and put a psu there..so I measured out and made a sketch on the side of the case, to be cut with a plasma torch later on this week..
So now, it's time for blowhole moddage!
I took my trusty Black & Decker RTX tool...and hacked away..
And after about a half hour of more hacking...I had my 3 holes cut...
The only problem that I had was that my drill bit sucked balls and so I kept smashing the drill down onto the paint...but thats okay..its gonna get sanded and painted anyways...
And somehow, one of my screw holes is off...but I tried lining up my fan grilles...and everything _appears_ to be the way I want it...
So this is a side shot of the case...
I want to use this as a cutout on the side of my case, with a 80mm fan in the center...so if anybody might have some tips on cutting that out or drawing it on the case for a cut out for a non-visual type of person (I am not very creative!) I would appreciate it so much!
Lastly, this is where I will be placing the LCD's
So that's it for my first installment of this worklog....next time I post back, this case will hopefully be painted, and with the rest of the hacking done...it will sit dormant until I come home from college for christmas vacation!
