zapperfish
- Oct 29, 2004
Well after your help in deciding on a case theme for my Antec Aria, and then the help in deciding on what mods I should do. I have started project Batman W.Aria, or water cooled aria. Well I hate reading shit and always look at the pics so I think ill get on with them.
[Marking out the front panel] - 120mm fan
[Marking out the case for front fan] - 120mm fan
[Front of case cut out ready for a fan to be mounted]
[The drive cage cut out] - so that it wont hit the top of the fan
[Front panel cut out] - all the holes will be filled
[The modded fan so it will fit in the case] - soz for the shit pic but i had to take it like that so you can see it properly
[The fan front]
[The fan back]
[Fan mounted so you can see what it looks like]
[Fan mounted with front panel on] - i will be making my own grill for fan so it will look like the batmobile
Things to do
-120mm fan at front will batman grill
-White and Yellow CCFL's
-Some way of projecting a batman symbol onto my ceiling/wall
-Batman window etch looking at the symbol
-120mm fan to look like intake of Batmobile
-Gloss Black outside paintjob
-Bat Belt, use it as a stand for the case and put the cardreader, USB, sound, ect. and power botton into the belt
-Batcave inside the case
[The fan front]
[The fan back]
Things to do
