Hey guys, I've ordered all my stuff now and slowly getting all the parts together then I will begin modding my case to fit the new watercooling parts. I will update this worklog, as I make additions to the case...
Firstly, these are the parts I'm ordering/ordered:
(All prices are an approximate of when bought and are in AUD)
SILVERPROP CYCLONE FUSION HL GPU Block $80
Dangerden Fillerport - 1/2" - Colour Choice $19 (Silver)
3 Meters of TYGON R3603 1/2" ID HOSE per metre ($18) = $54
SWIFTECH MCP-650 12V Pump $149
Polypropylene "T" 1/2" $3.50
Silverprop Silverstorm 4 Radiator (Bought for $80 from forums, pics below)
2 x 120mm Fans ($45 from forums)
Nexus SX chipset cooler with intel clip $80
Cathar's Stormblock G4 (For Socket LGA 775) (Still to be ordered)
I am still up in the air for the best way to go about taking off the top panel for modding. I know i will be dremeling it out to fit the rad/shroud but unsure if i should just remove all my components and dremel with it attached, or if i should go out and buy a pop rivert gun and do it that way...
Pics so far:
Radiator:
http://members.iinet.net.au/~yodaentropy/bandit/rad1.JPG
http://members.iinet.net.au/~yodaentropy/bandit/rad2.JPG
http://members.iinet.net.au/~yodaentropy/bandit/rad3.JPG
Radiator has a few scratches, I'm probably going to buy some car touch up paint and make sure it looks all good before it goes in
Case in current state:
http://members.iinet.net.au/~yodaentropy/bandit/case1.jpg
http://members.iinet.net.au/~yodaentropy/bandit/case2.jpg
http://members.iinet.net.au/~yodaentropy/bandit/case3.jpg
Mods done so far:
Bought the PC-65 Window kit, added a huey applique
Cable sleeved (vantec kit) my Antec Truepower 480W
Why watercool this system?
Well, mainly because i have a Prescott LGA775 3ghz, and under load (for example in NFSU2 and HL2) i get temps of around 65-70 Degrees! :O
Any questions or comments or even suggestions are most welcome!
Thanks
Pics so far:
Radiator:
Mods done so far:
Thanks
