Emission
- Dec 6, 2005
In the fear that I may lose some of your interest with a long drawn-out introduction, I'm revising my explanations to make everything short, sweet, and to the point.
I'm building this because I need something more portable. I can't be bothered with a gaming laptop because it's too expensive and not modular enough. I mess around with my computer too often, the laptop would bore me after a week anyway. Of course, who doesn't love a good project?
ARIAS stands for A Rig In A Suitcase. I'd say this is fairly self explanatory. The suitcase part, well, it's the most advanced suitcase I've ever seen!
Design Considerations:
Relatively small size.
It needs to be small enough that I can still call it a suitcase, and rival the portability of a gaming laptop (not that easy, but I can try). Of course, it needs to be big enough that I can fit a full ATX board in it, because this means I can use 90% of the boards on the market, so my choices aren't limited.
Cost Effective.
Here's the big one: I'd like to keep my arms and legs. This is one of the main reasons I'm doing this project in the first place. Gaming laptops are too expensive, even if I was to settle for one of those, I couldn't afford one that fits my computing power needs.
Modular.
This goes hand-in-hand with cost effective. High-performance desktops can be cheaply built these days, and if all I have to do to upgrade every now and then is swap my processor or my graphics card, then I'm set for a very long time (relatively, this IS the computer world after all). I'm in love with this idea, and I'd love to be able to keep the actual case for a good long time too.
The Prototypes Thus Far:
Prototype 1, ARIAS-000:
What this prototype has accomplished:
- Easy to pack computer setup
- Much quicker to pack than a typical setup with tower/monitors/etc
- Easier to transport, it's got wheels and handles
- Indestructibility is a plus with this particular design, as well as being water-tight when closed
- Able to use 100% desktop parts with this particular design, including the recycling of one of my desktop monitors without any major modifications.
Drawbacks:
- Freaking huge.
- Did I mention huge? Just checking.
I've never been able to pack my entire setup in less than 5 minutes before, and this was probably the best part of this prototype. It was easy to mount all of the parts straight from the tower into this box. The motherboard tray and removable HDD cage were salvaged from the damaged remains of my tower. The tray had to be persuaded to fit, but once I finally figured out the orientation, everything else just fell into place. I'm also thoroughly impressed with how well industrial-strength velcro is able to keep my HDD cage in place. Granted, I used two whole pads of it, but it is firmly in place. After surviving the 500 mile trip home, I'm convinced of that. The empty spaces in the box were actually used for a bunch of other crap, the box was stuffed, and yet the computer was still intact and perfectly functioning after unpacking all that crap and setting it up again.
Now, what I do *not* love about it: It's huge, forget trying to put this thing on your lap, let alone a desk. Maybe a short table at that. Given the size, the entire thing is almost as big, if not bigger than a Cooler Master HAF-X or equivalent cases. Pretty sure it's thicker anyway, in relative respects. I got all excited about the case when looking at it on ebay, and it was much cheaper than almost everything its size and most things smaller, also indestructible was an exciting plus, but that is going to be another consideration for the next prototype in terms of keeping it durable AND relatively small, much smaller than this box anyway.
Continued in the next post.
Cost Effective.
Modular.
Drawbacks:
- Freaking huge.
