Project Arclight
tobyak
Behold my latest creation to be
Project Arclight will be a huge case built on an Enermax Fulmo GT chassis with some serious power behind it also provided by Enermax in the shape of the mighty Platimax 1200watt psu
Te Arclight will be an all acrylic outer shell with a double action doors and servo actuated fan intakes that will open and close based on fan speeds, the shell will have a double tone look with layered panels of black and flourescent blue to accent every edge even the 100s of vent parts will have glowing edges, the interior will be a partitioned system very much like the custom partition for my other project "Sulaco" but with far more refinement
Much of the details i would like to keep slightly underwraps untill I post them for that extra mystery, heres a little peek at the exterior
several sponsors are already assisting me on this build and there help is as ever massively appreciated i simply would not be able to do this without them
Acrylic and solvent supplied by Hindleys. These guys are amazing, catering for 100s of different types of materials from plastic to metal and everything in between. And allays happy to answer even the craziest of questions a modder like me can ask
Massive thanks to Enermax for supplying a Fulmo GT, Platimax 1200wall and a vast array of case fans from there amazing Vegas range
Thanks also go to Bitfenix for givign me so much on my last project that i have enough spare to add to Arclight
Stay tuned for a lot more to come........
Arclight was origionialy designed for the Enermax fulmo GT a huge and brillicnt case, but time has marched on and Azza have offered me the chance to use there superb Genesis 9000, so a little redesigning was called for,
Concepts for the intakes have been redesigned to better fit the new chassis and all the electronics have been brouht in and in some cases teaching myself arduino voodoo
Heres the first batch of parts going in to the chassis
the origional blade design and array have changed slightly from this
to this
The array control mechanism of a pull rod attached to a servo will remain much thesame as the origional
Some parts will need to be scrapped or completely changed to fit the new body shell such as the origional concept for the sides
the new version will be a wait and see but they look great in the planning
Well this project will need a huge number of mechanical and electronic parts in top of your typical PC set up
This arduiuno kit courtesy of Phenoptix is a great start to the project and will be controlling several of my lighting systems including a rather clever hack of a LOL shield
LOL shields and old school bar graphs will be making quite an appearance as accenting lights, and yes there will be larson scanners
Servos and actuators will be making a big appearance including several mechanized fan intakes and a large front panel "shield"
And to wrap up this update and REBOOT, Kingston have graciously given there support and provided some of there swesome products
the amazing HyperX 120gig SSD
and a quad kit of DDR3 2400MHZ RAM
Stay tuned
Just a little update today
An absolute ton of cutting and sanding today
Well i dont have access to a lazer and i need a lot or duplicate pieces to were rocking it old school with a stencil
And what better to cut out my many many parts than a home made table saw, complete with mitre fence
Problem.... no sharpie..... solution... stick paper to plactic cover on acrylic and use engineering pencil... copy template.... move.... repeat.... over, and over
and now its on to cutting
first up divide the sheet up in to manageable blocks
then drill holes for turning the cutting blade in
some more cutting to further separate each component
first half done, all rough cut
bit of refining the shapes to reduce sending
sanding time...... 1 of 24
and yes that is a dyson taped to the extraction port
all done for the day, 24 pieces of the main intake array rough cut and rough sanded
i may never want to see acrylic AGAIN after this build....
Although ive had a long break from posting my work has continued, i finally have time to sit and type
So i shall pick up where i left off
The rough cuts were plastic welded in to pairs of one blue one black each with liquid dichloromethana injected in to edges to form 12 completed pairs
After coming off the sander for the first time the edges are still as rough as a badgers behind but the biggest thing to address is the notch in the top that neither the belt or disc sander can get in to
So out come the hand files
4 hours later and the stack is complete
The edges still needed quite a lot of refining so on to the hand sander
.... I broke my sender.... just imagine a lot of swearing and a run to the shop....
After sanding...
A little test fit and tease before polishing the edges of each intake
Three hours of polishing with a drill press slightly modified to server as a bench grinder/buffer and we have....
another 2 hours and we have a result
A long time to finish from rough cut to finished intakes but they do look damn good if i do say so my self
Next up, modding the roof and base plastics
Time for the update that has been a long time coming
As most of you know the case changed from from an Enermax Fulmo GT to an Azza Genesis 9000 as the Genesis offered a stronger frame and more internal space to work with.... before work started it looked like this...
and the chassis itsself looked like this..
IIt is a brilliant reverse ATX chassis, very well made and strong enough for an 16Stone man to stand on, BUT as is the case with mods some structure needed to be removed so after an hour with a drill we have
Frame all ready to measure up the floor panels and internal enclosures
As this case is somewhat modular in terms of its plastics i was freed up to mod sections in waves rather then all at once
starting with the floor plate, this would also serve as a test run for the metals replacing all the red inserts in the bezels
The base plastics are very heavy built and massive
But the vents need to go to make way for metal inserts
Perforated plate form ebay makes freat replacement vent intakes for the floor
Ahh hot glue what would i do without you....
All good mods start with a plan.... well thats me out of the window
But at least i got some penile work done measuring up the plastics for the enclosures
Overkill 120 grills make handy stencils of.. erm... overkill 120mm grills
Acrylics cut to size and welded with Hindleys Dichloromethane
Ahhhh all snug fitting
The psu, most of the tubing and a very thick 60x240mm rad will be housed under this.
This 60x240mm rad to be exact, with a pair of Enermax TB silence 120mm fans on pull configuration
Sharing the floor will be an Enermax Maxrevo 1200Watt fully modular PSU... it is MASSIVE
I may have to many spare cables
To kill some time waiting for some parts i partook in another of my favourite basstimes... no prizes for guessing what these 2 SciFi icons are
Plastrics cut and marked up for the optical bay covers, the optical and hdd bay area will house both pumps as well as most of the tubing of the twin loops and access hatched have been cut in to the floor compartment to get to rad fittings and install cables and tubes
First test fit of all the enclosures plus checking that weight of the res holders will not warp the top of the enclosure
Pass through holes cut for Tubing to and from the twin res, due to access the PSU, bottom Rad and main PSU looms are already installed in the lower enclosure
Well that's enough of the enclosures for now on to the roof again
After installing the rails and letting the welds cure in go the 12 vent components in to there sockets, until the retention arm goes in they can move through 140deg
I suspect that Dust is going to be an issue... just a hunch
but DAYUM they look good lit
I made a small plate to hold the servo, amazingly a tiny 9g servo can pull the vents, the full array weight close to 3lb
Yes i know the metal wire is a little ghetto but im waiting on an RC pull arm
With most of the structure and covers complete i can start the loops, that was a tad more involved than i expected, clearance between the top of the PSU and the Top of the floor enclosure is just big enough to get a 1/2 OD tube through... and i need to get 6 through it
Starting off... install res and attach to mounting blocks on the floor, plus attaching the main tubes from the CPU and MB waterblocks and taking then to the bulkhead
Next up install pumps and run feed tubes through the floor plate to the lower rad and run the outputs to the waterblocks, as i side thought i added a fill port and hooked up the top 360 radiator to complete both loops
Well at this stage i was going to fill my loops but my daughter has other ideas
After a short fight that i eventually won with a stunning pile driver i finally filled the loops
yay its leak free.... well it is now, it kind of wasn't but lets not talk about that.... nothing to see here... move along
Construction is 90% complete and its already in service as my main game machine, side door needs a window and massive changes are going to be made to the front of the case
So im going to show off some of the key features so far
modified intakes and bottom deck enclosure
Access ports
Concealed tubing
Tidy tubing with bulkheads
Back plate mounted SSD and HDD
Damn good lookin if i do say so myself
MUCH MORE TO COME
my first thought "I've gotta see a video of those vents in action"
looks like I was not alone lol.
Awesome work so far. Keep it up.
lol yeah, looks like it is a "by popular demand" ile get my driver and camera set up when i have some peace form my legion of kids
I am VERY pleased to announce that EK is now official sponsoring Arclight, they are kindly supplying enough equipment to rebuild the entire double loop set up
Stay tuned for a supply drop and more updates
Subbed so hard I think I broke the link.
Congratulations on the sponsorship - I don't have to say that EK makes phenomenal products, but I will anyway. Can't do much better than that.
This is going to be and is an excellent build! Very cool.
I especially like the jigsaw converted into "scroll saw". Very clever!
It is finally time for an update
As most of you know by now a short while ago i acquired a small CnC mill with which to being my twisted imaginings to reality.
here is how it went
As i completely forgot where i left my shots of my mill here is a stock shot of the exact same model, I was rather dubious of the quality of the machine as it is a cheap ebay Chinese machine but after ironing out a few bugs i do haft to say this is a great machine.... i had to mod it of course
i had heard that as the boards in the control boxes were generic i should find additional headers for a probe and limit (home) switches
just what i wanted to find, headers for limit and probes, idon'tcurrently have a need for a probe but a limit (home) switch is a must have
finding areas to mount the switches was a little tricky given the spaces i had to work in. i wont bore you with the details/
starting simple learning my way around the machine and everything went well..... if you forget the time i put an engraving bit part way through my T slot bed. the end result for a simple quick run was rather impressive although settings still needed some refining/
the first proper case parts to roll off are roof intake vents, the original vents took months to make by hand but with a cnc i can improve on them and get perfect results in just a few hours to cut all 30 of the new intakes (more about those in a later update)
once my confidence with the machine grew i finally ventured in to alu milling.... with TERRIBLE results, screaming mill and terrible tooling marks. after 3 weeks i finally worked out what was wrong, no coolant/lubrication, so out came the WD40 and away we went
the arclight main bezel for the front of the roof if a plane sheet of 1.3mm alu shaped and contoured to fit in to a recess in the existing factory plastics
to say that the milling went very well would be an understatement, the results are fantastic, i will be doing way more alu work in the future including my own custom grills for sale
the lesson here...... WD40 is your friend
on to the REAL work
some time ago i designed this bezel for the arclight based on the mk7 ironman cheat arc, at the time i did not have the ability to bring it to life..... now i do
and so the madness begins
starting with a massive block of plexi (300x200x20mm) and a psychotic grin, the mill went in to action, to keep a fairly good finish and prevent melting of the pexi, i invested in some coolant (you will spot the chips chance colour a few times depending on the coolant i am testing in each phase)
the endmills i am using are designed to go no deeper then 12mm and i am going down to 20mm so lots of coolant is being used to try to push the working limits, and thankfully it worked far better then expected
the above shots represent 3 hours of mill time, going super slow to avoid trouble
Very cool man! I just built something similar here.
If you're having trouble with the plex melting and it took 3 hours of machining time to do the above pattern, I'd say your feed rate is too slow. It is seems contradictory, but if you're moving to slowly through the material your chip load is too low and your end mill just ends up rubbing in one area for too long. Good chip load, especially when cutting aluminum, helps carry the heat away as well.
I'm not sure how rigid your machine is, but you may want to try slowing down your spindle speed and upping your feed and increasing your depth of cut. From the looks of it your DOC is 0.5mm or less?
What's your:spindle speed? feed rate? doc? # of flutes? Oh and what allow aluminum sheet was the Arclight cut into? 5052/6061? (sorry for all the questions, I just like seeing someone else into this stuff)
Anyways, this is an awesome case mod! I love it! Excellent design and concept, I'm really digging it :D
ive done a lot of research in to feeds, this is also a cast, make up (due to supplier) being more similar to lexan then true acrylic so the melting point is through the floor, im also limited on speeds with a max rpm of 11k, ive bought some metal cutting pol and its fixed the melting issue. depth, endmill size and step over are factoring too... i think ive found a happy medium now
DOC was 1mm with 2mm stepover, 2flute 4mm endmill, the depth is the problem as fo speed overall, im gettign chip compacting in the edges as im running with flutes and part of the shaft in the cut so clearing out is a time killer
the alu sheet is 6061
nice machine you have, far more advanced then mine, but for £650 im very happy
Ah, I see. Didn't think about the piece being cast. Yeah you do have to be tender with it don't you!
For the chip compacting problem, I'm assuming you're using an up-cut helix? Air blast might help clear the chips as well. And you can even go with an O-flute for quicker chip evac.
Looks like the machine is performing quite well for you! Nice to have the right tool for the job, you know?
Keep up the great work on the case mod!
yes up cut clockwise, the compacting is more due to the geometry im cutting then any tooling issue, air is working well for the most part, added a small holder for an airbrish and currently modifying a hydroponic plant drop feeder to supply coolant
some 1f endmills are on the way om hoping that will help too, ive special ordered them with 22m useable flute
continued......
after getting the centre to full depth the tricky work can begin, the endmills i use have a flute that is 12mm long, this limits me to 12mm depth or i will not get any kinf of chip evac when cutting......... but i ignored that and took them 20mm deep
mach3 with custom skin displaying tool paths and the current positions of the axis, just about to start fork on the epics above
i am skipping sections of programs or making ones that leave out large areas of the design specificaly to allow me more sway room as i get closer to completion
first roughing (horizontal roughing) for one of the arms, using vegitable oil (liberated from my chip pan) as an ad hoc lube, as this is cast plexi it melts if you even breath on it. the tooling looks a bit rough as ive not cleaned up all the debris in the shot... the results even at extream depth were very pleasing, although oil as lube does make the chips look horrible and a nightmare to clean up
the eagle eyes may notice the slight lip on the bottot of the right arm, after finishing the left i decided to change max depth to 19.5mm to give me a ,5mm tab to help keep the part stable later and to stop the coolant from destroying my baseboard
continued.... erm.... some more
back to milling the center this time leaving zero stock, this was make or break, if i had planned anything wrong the whole piece would be ruined, but it seemed that lick was on my side
full cleanup can wait until all the cutting is complete
for some scale
many many hours later we have this, i quite like the liered effect of the roughing but this is destined to have a smooth finish
finishing took less than an hour, meer seconds compared to the time the entire roughing took
and this is what we and up with
well thats me up to date, more updates in a week
That is very cool! Nicely done, sir.
I know you'll be sanding out the tooling marks, but I've always liked the look of them before they get finished of.
What cam software are you using?
Visual Mill 6.0 for the path generation
So its not just me who loves tool marks... yay
CAD Solidworks 2012
CAM Visual mill 6.0 with Visual CAM 1.0 pug in
CnC control Mach3 2.1
This is awesome. I really like the way you have the reservoirs mounted in the case. The tubing looks very clean too. Nice work.
I will be reworking the res slightly, i need to swap them for EK multiport 150s and add a GPU block, not sure how i am going to get space for that so i am open to suggections
just a quick message to my followers
I have been rather ill this week and completely unable to even look at a power tool let alone operate it safely, i am now recovering and will be back to my insane self in a few short days
Hi tobyak, I'm a representative from Enermax, and I just wanted to say that your work looks amazing! What a massive undertaking, and I seriously can't wait to see it finished, cheers!
Thank you very much, lots more to come over the next week
Did you go push/pull with that lower rad since fans will fit inside the lower tunnel? Crazy rad room with all 9 5.25" bays (yes 9) gutted. Nice project, will be interesting to see it when finished.
I have this case, but it's not modded. I just added the extra side fans and run them all at 7v (LED button off runs top & bottom fans at 5v), and my CPU fan is far louder than the rest of the case. It's actually a pretty nice BIG case.
The lower rad is super thick 66mm, plus fans on top 91mm, the space under the cover is only 110 and i needed to get tubing in the spaces, fans are running 900RPM in push, the rad is quad pass so so far it is working just fine with the one stack of fans
i'll be interested in seeing how your tubing looks in a month or so after using the mayhem's pastel. pastel white totally leeched my masterkleer tubing. I'm using Mayhem's Deep Red + Distilled now hoping to avoid the plasticizer leeching. same thing happened to Tom Logan (TTL/OC3D), turned his tubing chocolate brown.
IM BACCCKKKKKKKKKKKKK..... it has been one hell of a year but i am back and Arclight is still alive. I am sorry to anybody whos replies i have missed for all this time
BEHOLD AN UPDATE.... yes, yes, I know, took my sweet time. HEY!! you try modding and having 6 kids
So where were we, Time for the Arclight front lower bezel, the AZZA9000 has a split front bezel due to the front mounted PSU, After several weeks of anguish I finally found an intake design that fits the theme, twin Horizontal slots it is!!!
TO THE CAD SOFTWAREEEEEEEE!!!!
Not the most complicated design by a long way, but the look im going for is very stark
Once the dimentions are worked out for the raw material its on to cutting out some 1.3mm alu sheet, time for the new toy
AND YES I DO HUM THE JAWS THEME WHEN CUTTING
I had been debating for a while on buying these but for under £20 worth a shot
I am actually quite impressed how easy they are to cut wit and how accurate you can cut... as an added bonus the bi-product seems to be "traditional" jewelry.....
IT has been a while since i fired up the mill so after a lot of maintenance (read playing with WD40)we were back in action
..... And yes, i do love taking pics of the mill running
All done, the opposite side has been shelled out at the ends a little to make bending easier for fitting
Bring on the rough sanding and surface finishing
Damn did i really let it get this dusty
10mins of rotary tool and some cussing at a piece of plastic in the eye (keep those glasses on kids!!!!)
15mins of hammering, inc getting told off my my wife for using the metal legs of the kitchen units as a former to hammer on......
Shaping was a lot easier then i expected (i have no metal forming tools bar a very large rubber mallet), mostly thanks to the shelling i did to the ends on the mill
one final test fit
Heres a little context as to where on the front this piece goes.... yeah its massive
LATER.........
Once again Tauntauns are roaming Hell and ye another day has been spent modding, just a short update this time (someone who shall not be named forgot to take pictures)
picture several hours of cutting and filing......... Did you enjoy that?..... GOOD!!
And suddenly the insanity and clashing panel scheme makes sence
(IT AINT MODDING UNLESS YOU HAVE BARE FEET IN SHOT)
test illumination on the Arclight intake, whilst it was milled as all one piece i masked out the center and sprayed the rest matt black. The effect is a little too bright with the Vegas fan, i may spray the blades black and just use the ambient light from the ring of LEDs to illuminate the center
What do you think? leave as is or get rid of the reflection from the fan blades?
Stay tuned for more Arclight coming soon (I PROMISE) and a new side long project on commission to be called 'SMITE'. Watch this space
