SatTech
- Dec 5, 2005
Is it my imagination or has the points values increased to 1888?
You should be getting a bit more PPD than previously when the WUs were worth 1680 pts. My 8800GTs shot up several hundred PPD, so I figure at least 200PPD more for a 9600GT.Nope, I'm crunching a 1888 point WU right now. Project 5903. F$@! me, my 9600GT is getting crippled.
Hmm, which monitor are you using and can you update it with current WU data from Stanford?My GPUs are all on the 5904s at the moment and all show the wu as 1680 points.
FahMon and after seeing SatTech post, I did the same and see 1888 for the wu.Hmm, which monitor are you using and can you update it with current WU data from Stanford?
