Project 3038 and 3039
ND40oz
Anyone have any info on these? I just see points as 186 but can't really get any good ppd for them.
Supervillian is right.
p2124 gives around ~126 PpD, p3038 gives ~130 PpD on same box.
So another slow folder.
Luck .............. :D
Fahmon has the info on these, one of my borgs (C2D 6300) is reporting an average of 123 ppd and 21m 42secs a frame.
Jeez, that seems slow, is it overclocked or the stock 1.86? Mine at 2.66 is running 13:36 a frame.
Its a work machine so everything is stock, there are two instances currently running and at the time of the benchmark some one was working at that machine.
All of my single cores (3) still have those wonderfull 5 way melts (it sounds like it should be a sandwich)
Don't feel bad. My old Celly 2.6 laptop takes 35 mins/frame. About time to retire that old workhorse, as it's having a hard time of these larger/slower work units.
