D-OveRMinD
- Aug 22, 2005
I keep getting this damn WU over and over, and it keeps giving me the same error.
I am running two Ubuntu 7.10 VM's on Vista 64, both with the SMP client. One works just fine, the other keeps getting this problematic WU.
Here's the log:
Apparently, the 2604 and 2605 have both been this way for some time. But I need to know if there is a way to get past this. I just bought a q660 rig and now I can't even use it!!!!
Here's the log:
Now multiply that over and over...no matter if I delete the Work forlder and Queue files, it keeps pulling down that WU.[16:07:17] Project: 2605 (Run 4, Clone 37, Gen 7)
[16:07:17]
[16:07:18] 2605 (Run 4, Clone 37, Gen 7)
[16:07:18]
[16:07:18] Entering M.D.
[0]0:Return code = 0, signaled with Floating point exception
[0]1:Return code = 0, signaled with Floating point exception
[0]2:Return code = 0, signaled with Floating point exception
[0]3:Return code = 0, signaled with Floating point exception
[16:07:29] CoreStatus = 0 (0)
[16:07:29] Client-core communications error: ERROR 0x0
[16:07:29] Deleting current work unit & continuing...
