Programs for burnage
DrunKBunny
I am trying to burn from an image file (.bin + .cue), and have had some crappy success with Nero and Alcohol 120%. I put in my blank cd, select burn from image, and point to my .cue.
In Nero, it burns up to 100% and gets stuck there for about 40 mins, until it says burn process failed.
In Alcohol 120%, it burns normally and it says it is successful, but the result is a disc that is as blank as ever.
I have an HP CD-Writer+ 8100 with a max burn speed of 4x, and I am running Win2k if that helps. The thing is I can burn smaller files that are 500-600 megs in size, but when I get to the .bin files that are about 800 megs ( when you point to the .cue file it makes the .bin about 700 megs), it starts to give me trouble. Anyone know how to fix this or have any recommendations on other burning progs that may work?
Check this guys site out. He also has an ISO maker bundled with an WinXP burner .... but you can use them independently.
http://www.paehl.de/home.htm
Another one is called "DeepBurner" ... you can google for that site.
Bin CUE was started by GoldenHawk Im pretty sure.. So try their software, CDRWin..
