Nazo
- Apr 2, 2002
Well, I've recently discovered that you can use start to do this with NT (XP, 2K) but the problem is that, at least with XP (don't know about 2K or below) start is not an actual executable, but, a command known only to the console command interpreter (cmd.) This is rather bothersome. Does anyone know of a FREE program that can do such a simple thing without having to go through cmd? I've found a couple of commercial things with a bunch of extra stuff and they don't even directly run the program, but attempt to set it to low after you've run it.
As for why I'd like to do this, there are several programs -- such as the weatherpulse program I used to use (found better) -- which just love to eat up free cycles sometimes. Terribly annoying when you are trying to play games that rely heavily on the CPU like Far Cry...
BTW, for those who don't know, the syntax to start things like this is simply add the priority name after start like so:
START /LOW C:\TEST\TEST.EXE
But, to run it through the registry or start menu, you have to first open the command prompt:
CMD /C START /LOW C:\TEST\TEST.EXE
Unfortunately, you run into issues with things like quotes. And I can't very well go through and set EVERYTHING to use only short filenames. It becomes quite tedius after a while. And it's very hard to find out the real short filename in windows (harder yet in dos since you don't get to see the long filename next to it...)
