Program to see PSU temp?
NathanP2007
Anyone know of a program thats reliable to show PSU temp? I currently have the nvidia program that shows the PSU and PCU temp but idk how reliable it is. Thanks guys
None exist. The closest you can come is with a digital thermometer.
They would only work if you had a temperature probe that you could connect to the motherboard somehow...
You can get temperature probes with display readouts that go in drive bays
Get a Gigabyte Odin GT PSU and monitor voltages, fan speed and unit temp through he P-Tuner software. :D
Or.... Get a 780i motherboard and an ESA comliant power supply and use Nvidia's ESA program to monitor.
Otherwise, aint going to happen because the PSU has no communication interface with your motherboard.
