Program to identify what camera took the picture
iakona
Hello, I had a program that could do the above, but forgot the name of it...I'm sure there are several so any would do...
I think you're looking for an application that can read the EXIF information embedded in an image. For that there are many available, including some web browser add-ins.
I use IrfanView as my image viewer, and if you install its add-ins you can hit "i" to find a button to display EXIF information. I also just installed some Firefox Add-In that shows EXIF information...I think it is called Exif Viewer (version 1.30), and it seems to work pretty nicely. Cheers.
If you just want the quick and dirty, right click the picture -> properties -> summary -> advanced. There is general/extended EXIF data there.
