GaleForce
- Aug 7, 2004
I like to take pictures with my digicam but I HATE resizing each one in photoshop. Is there a program that you can dump all your pics into and have it resize all of them? Thanks.
aBSoLuT_0 said:There is a function in Photoshop where you can write a batch script and then apply it to any/all pictures you want. I believe it just records actions/mouse clicks, so it's pretty easy to do. I haven't used PS in a while so I'm sorry that I can't be more descriptive...
Lethal said:IrfanView will do batch re-sizing as well and it's free.
i use that occasionally and it works just great, right click and you're there. only problem is you can't customize the naming scheme for the new filesJason Isom said:Assuming you're using Windows XP, Microsoft has a PowerToy that does batch resizing of any custom size (http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx)
