I recently started programming full-time. I have a Catleap Q270 and its been great, but the glare from the screen is starting to take its toll on my eyes. I am working for 8-10 hours a day, and I do not think the Catleap was made for this type of work.
I'm looking at replacing it with two 1920x1200 monitors with AG coating. I would go with 2x1440p monitors with AG coating, but I can't justify the cost at this point. I also need more than just a single input since I switch between PC and Mac. The single DL-DVI of the Catleap is a big limitation. I'd also like a USB hub as well.
My work consists of Photoshop/Illustrator CS6, programming in general, and reading documentation. So, I need something that is easy on the eyes, but also has decent color replication. I am not doing print work.
What monitor would you guys suggest? I am currently looking at the PA248Q, U2410, and ZR2440W. The USB 3.0 of the PA248Q is nice, but I've heard of backlight bleeding problems. Price is not a huge issue. Up to around $400 per monitor would be fine, I just want the best in the range.
Thanks
Thanks
