Prodigy Casemod
System Specs :
Bitfenix Prodigy, Custom Sidepanels with Aquaero cut out, Little Devil Casefeet
Intel i7-3770k with XSPC Raystorm
Asus P8Z77-i Deluxe
Corsair Dominator Platinum 2x4gb 2133 CL9 @ 1.5V
Corsair AX 650
PoV GTX 680 with Watercool Black Hole Edition cooler and backlplate
System : Crucial M4 128GB
Games : Crucial M4 512GB
Storage : WD Scorpio Blue 1TB in Sythe Mini Himuro
Watercooling :
Bitspower Black Fittings
Tygon clear Tubing
Laing 35X with Alphacool Plexi Top
Aquacomputer Aquaero 5
EK RES-X3
240mm Magicool and 140mm Magicool Slim Radiators
Noiseblocker PL2, PK2 Fans
Aquacomputer DP Ultra Blue
A basic plain white Prodigy
Looks much better without the handlebars
First hardwaremods :
Vanilla P8z77-i Deluxe
Cleaned
Dominator Platinum added
Raystorm Added
Cut the mainboardtray and shortened chables
First mock up of the cooling Hardware.
CAD Time
Sketch of the Sidepanels with Aquaeroholder and covers
Printout fits allready, waiting for production
Fits :D
Rear mods
2x holes to connect to external Radiator
Power for fans on external Radiator
Power+Reset Button of a LianLi V351
Assembly
Some light shots
Final shots
Closed
Open
Big Thx to Bitfenix for the case
An even bigger thank you to my other Sponsors, my wallet and my creditcard ;-)
Nothing like that would have been possible without you two.
Very Nice Work!!!
What size rad are you running outside the case?
I´ve a Watercool Mora 2 sitting under my desk which is fitted with 4x180mm silverstone Fans. Sadly it´s still filles with Red DP Ultra at the moment
At the moment I get Ambient + 5°K with the internal rads so it´s not a big problem
This is an awesome mITX build. I' planning on modding a case and making a work log. Just can't decide on exactly what I want to do.
Thanks for the inspiration.
