StefanPeeters
- Oct 7, 2013
Hy,
I am trying to create vlans but for some reason it doesn't work. I hav a procurve 1910 and two procurves 1810. In the 1910 switch I configured it like this:
First I go to the left hand panel and click on IPv 4 routing. Then I click "Create" in the Destination IP Address and enter 0.0.0.0 and Subnetmask 0.0.0.0. Than I fill in the IP address of my router 192.168.4.1. I select preference and enter 2.
I am saying to the switch that the swich all receiving traffic will be sent to my router (next hop). On my computer I set the default gateway to 192.168.4.50 (IP address of my 1910 switch). Now I'm able to ping to the switch, router, and address on the internet.
Now I configure the vlans to my switch. First I go to Network, select VLAN and create. I type 2 in the field VlanID and click create. Than I change the name. I repeat this for all my vlans
By default every port will be untagged in VLAN 1 so I dont make any modifications to this. I click Select All, then Tagged and last of all Enter the VLAN IDs in this case 2,3,4,6,11,14 and click Apply
You will receive a pop up letting you know that Access Ports will change to Hybrid Ports, Then I click OK.
Than I assign an IP address to every Vlan.
After dooing this I can ping to every IP address.
This is what I do in the layer 3 switch (1910). Now I go to my layer 2 (1810) switch and start the configuration. First I give an IP address and Subnetmask:
192.168.4.51 255.255.255.0. Than I go to the left side and select Vlan. I click on create Vlan and type 2 in the field of VlanID. I do this for all my Vlans. After I did that I go to Participation/Tagging and select 2 in the drop down menu. I select ports 1 to 4 as Untagged because I want to connect pc,s to it. After I saved the configuration I connect a Cat5 category cable to port 1. On the other end I connect a pc. That PC cannot connect to the internet. I configured port 8 of the layer 2 switch as a trunkport. Is there something I can do to make this work. I can't find where the problem is. All help is very welcome.
Thanks
2
3
4
6
11
14
192.168.2.50 255.255.255.0
192.168.3.50 255.255.255.0
192.168.4.50 255.255.255.0
192.168.6.50 255.255.255.0
192.168.11.50 255.255.255.0
192.168.14.50 255.255.255.0
Thanks
