Processor intensive mouse
shadowsz14
I brought up the performance console, and my processor is taxed just by moving my mouse around. What is going on?
I think you've got your cause and effect backwards. Something is taxing the system, so the mouse cursor is moving slowly.
If I keep the mouse still, the processor utilitzation goes to zero. If I move it quickly, the utilization goes to 50%
Which mouse is this? Have you installed drivers for the mouse?
The mouse is a Kensington optical, and the device manager shows it as being installed
Seeing a performance bump is normal, but the most you should ever see it go up to is like 7%.
The proceess that was jumping was the DPC. I had a problem with high utilization with a logitech stick before, and I had to completely remove it to make the problem go away
Thanks for you your help
